Altezzas not flush on car (Anyone have that prob)
Old May 30, 2002
JackTripper's Avatar
JackTripper is an unknown quantity at this point
I got some altezzas that dont fit flush. they stick out on the pointy corners and don't go in. anyone fix the prob or should i try to return it?
Old May 30, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
try pushing them in more, if not
return them...
Team Turismo
Old May 30, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
What Brand did ya get??????
Old May 30, 2002
RegulatorRacing's Avatar
RegulatorRacing is an unknown quantity at this point
Same thing happened to me man and it was sooooo annoying... I pushed and pushed and pushed and still they popped out the sides. I was afraid even goin to a carwash thinking they would get ripped off.... anyways, I ended up takin em off.
Old May 30, 2002
INCAEXtacy's Avatar
INCAEXtacy is an unknown quantity at this point
Well that is one thing that you are just going to have to deal with when you put non OEM parts on your car. If they are too warped or distorted looking, then try to return them, but otherwise not everthing it going to fit perfectly. [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 30, 2002
They were the KS atlezzas aka angel eye altezzas. They look good but just don't fit.
Old May 30, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
hope my TYC's for my sedan dont do that to me ....should be getting them in a couple days
Old May 31, 2002
luldude's Avatar
luldude is an unknown quantity at this point
I had that problem. One wouldn't fit flush and one would. I checked out the one that didn't and there was a screw that wasn't all the way screwed in on it. I guess they just half a**ed it when making them. I screwed it all the way and they fit fine now.
Old Jun 2, 2002
Atrain's Avatar
Atrain is an unknown quantity at this point
Hey man i had the same problem. i bought them from a place in orlando and i installed them. there where not flush on the corners. so i sent them back. i got another set in return, they fit a little bit better. eventually (1.5 months) they started to pop out. so guess what i have a set and i cant do anything with them. i ended up putting the stock in because the 2nd set chipped the trunk. well peace out.if you know of any sets that fit properly please let me know. take it easy and happy driving.ADAM
Old Jun 2, 2002
Sosojef's Avatar
Sosojef is an unknown quantity at this point
anybody have a pic of that grill
Old Jun 2, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
make sure your screws are tightened all the way, thats what happened with my Matrix tails when I had em, once they were tightened they were flush.
Old Jun 2, 2002
Handog's Avatar
Handog is an unknown quantity at this point
I ALSO HAD THAT PROBLEM BUT I FIXED IT BY LOOSENING THE TWO SCREWS AT THE EDGE WHERE THE CORNER IS AND TIGHTENING THE REST REALLY TIGHT AND I DONT HAVE THAT PROBLEM ANYMOE.
Old Jun 2, 2002
Spider883's Avatar
9K Redline Owns U
Please dont type in caps
Old Jun 4, 2002
Jadastyles's Avatar
Jadastyles is an unknown quantity at this point
i bought mine at speedpeople.com and mine fit fine but it was hard getting the stock lights out because they had so many screws, me and mah bro just ripped them out and placed the altezzas on and man do they look sweet, ive had them since winter and i have no problems with it
Old Jun 4, 2002
03Eclipse's Avatar
03Eclipse should not be trusted03Eclipse should not be trusted03Eclipse should not be trusted
what does it matter if he types in caps or not??????????
Old Jun 4, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Caps denote shouting on internet lingo..plus, its annoying to read.
Old Jun 4, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
i have this problem w/ my matrix altezzas (custom black by the way they look phat check em out)....im going to try some of the advice given by you guys to fix it...thanks....
Old Jun 4, 2002
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
My friend had the same problem with his '01 accord coupe. turned out that the gasket it came with was pushing the lens out at the corner. After many hours of slightly trimming the gasket and test fitting it, he finally got it flush. It could also depend on who you buy the lights from and their quality of fit. Some of them are probably cheaper and will never fit the way they should. However, you could probably trim the lens some how, just barely, so it will fit. I dont have them on my sedan so I wouldnt really know how or where to go about trimming them.
Old Jun 4, 2002
03Eclipse's Avatar
I realize that caps denotes yelling, but it was obvious that the context of his thread was not meant to be yelled .........
Old Jun 4, 2002
fraga's Avatar
Wicked Moderatuh
It's like that with about 80% of the Altezza lights out there on the market. 40% of people know that.
Old Jun 4, 2002
KazzuM's Avatar
KazzuM is an unknown quantity at this point
mine do the same thing. you know what works. waiting a little bit. the spacer foam that came with mine was flat and not contoured in about 3 months the foam countered and they look all right. not too noticeable. dont tighten the screws too bad you could strip the seals and that could lead to condensation in the taillight.
Old Jun 5, 2002
lordryan's Avatar
lordryan is an unknown quantity at this point
mine never went flush. They still stick out a little but it's not to bad
However I do get condensation on the inside of the lights when it gets to wet and hummid
Does anyone have any suggestions to prevent that?
Old Jun 6, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
The solution is simple. Push in or lean on the part that is sticking out and tighten the appropriate screws to hold it in position. Tighten the screw inside closest to where you're leaning then work out from there to the other screws. If it's still not right, try loosening one screw and tightening another.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
CivicVoz
Apr 16, 2015 08:07 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
trevaaaa
Oct 10, 2001 01:23 PM
