M3 Mirror Wiring
Old Apr 28, 2004
shifthis's Avatar
shifthis will become famous soon enoughshifthis will become famous soon enough
M3 Mirror Wiring
I have searched all over and noone has ever come up with an answer to this. I just purchased the M3 mirrors for my 01 4dr civic. I cannot figure out the wiring. I have a red black and white wire coming out of mirror and then the stock harness that has three spots. but the only way I can get anything to work is if I ground the black wire which leaves two wires for 3 spots. When i play around and test them I can only get the mirror to go down and left and that is when I push up on my controls. (backwards). Has anyone done there own wiring for these mirrors. Please help.
Old Apr 28, 2004
Vteced02civic's Avatar
Vteced02civic is an unknown quantity at this point
Shift im in the same boat. Yours arent plug and play either?
Old Apr 28, 2004
shifthis's Avatar
nope, just three wires, and it seems like even if I did get the right combination that they still wouldnt work properly.
Old Apr 28, 2004
There is 3 wires in the oem harness, The problem i am having is figuring out what the 3 wires are(+ ground,etc.) in order to hook up my power mirrors.
Old Apr 29, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
car color mirror colors
blue/black - white
blue/white - red
green/white - black
These are the colors for the drivers door. It was pouring rain out so i wasnt gonna pull the passenger door to look but just use the same pin alignment and you'll be fine.
Old Apr 29, 2004
shifthis's Avatar
Thanks, I'll try that and see what happens. So the ground is actually in the harness, you dont have to send any wire to ground to the vehicle anywhere?
Old Apr 29, 2004
Right shift, this is the way it has to be, thanx for the input.
Old Jan 25, 2005
jlew2's Avatar
jlew2 is an unknown quantity at this point
anyone know the honda color wires that the led part of the mirror goes to?? i need the blue and white to be hooked up.
Old Apr 2, 2005
Asdlkfjlaskal's Avatar
Asdlkfjlaskal is an unknown quantity at this point
how do i take the mirror off?
Old Apr 2, 2005
04vic's Avatar
04vic is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...d.php?t=155303
Remove trianglar cover piece above interior door handle, corner of front window frame other side of your mirror, that gets u 2 one bolt. look behind door opening lever, pry the face plate off. remove 2 screws.
On arm rest look down for small faceplate pry it open, remove screw, pull up smartly on armrest, look for 2 screws going into door..remove them..Remove door panel
For wiring signals remove/pull away front half of wheel well splash shield, reach up and find turn signal, disconnect and tap into them (refer link above for colors) run wire thru fender, door frame, into door and solder it...
need more just ask...
finding right wires is a bit tuff..maybe need to buy a couple of 4 amp fuses and if power mirrors they half work....
black is ground, red is turn and running lites, green is signal only says DIY, i did signal only....
Old Apr 15, 2005
mp3allday's Avatar
mp3allday is an unknown quantity at this point
M3 Mirrors
I am having trouble wiring the mirrors to light up if anyone has these mirrors please help me out with this.
MP3
Old Apr 15, 2005
04vic's Avatar
Step 8 for wire colors
http://www.7thgencivic.com/forums/sh...d.php?t=198872
http://www.7thgencivic.com/forums/sh...+mirror+wiring
Old Apr 16, 2005
mp3allday's Avatar
Awesome
Thanks alot
GotSiR
Jun 23, 2016 04:06 PM
jessicanicole
Jul 23, 2015 09:14 AM
sch2cm
Jul 21, 2015 09:58 PM
igorbogu
Jul 10, 2015 09:29 PM
robbie374
Jul 7, 2015 02:56 AM
