Installation request?
Old Apr 22, 2004
Pibe54's Avatar
Pibe54 is an unknown quantity at this point
Question Installation request?
I recently bought a jl 250/1 amp and two jl 10w0's in powerwedge box. I found this group of guys (consider themselves a team) who do installations for 25 dollars. All they ask is that I have all the supplies ready for them. Basically i just want to know what other items i need to buy to get all installed at once? is their a better installation setup i should request? My car is a 2001 coupe. ANY info or advice helps. Thanks
Old Apr 22, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
need a a/v or r/c tunner....cant remember but if u want to run the system off a factory unit u need it (it is a little convertor box thing (walmart has them for like 25 bucks). You will need an amp wiring kit......i would recomend buying a 4 ga. kit just incase u want to upgrade the amp in the future, but an 8ga would do (can buy cheap at walmart or on ebay)
Old Apr 23, 2004
LudlamTheory's Avatar
i boogie for the raindrops
amp kit, amp, box, subs, fm modulator (if deck is stock) electrical tape, either soldering iron and solder, or crimps, screwdrivers, socket set, wire cutters/strippers/crimpers, small blade, door panel popper, and beer.
thaats everything youd need for every single worse case scenario
Old Apr 23, 2004
HondaLuver's Avatar
Its a celebration bitches!
all i need is crimpers, buts, screw driver and lots of beer
Old Apr 23, 2004
doubledeuce2k2's Avatar
that must be amazing to not need an amp kit, box, etc...
have a coat hanger too, the #1 underrated car audio tool. it will help get the power wire through the firewall
Old Apr 23, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
you could also use a hi-level convertor... (as opposed to fm modulator)
Old Apr 23, 2004
Pibe54's Avatar
Thumbs down
thanks for all the help
Old Apr 28, 2004
Pibe54's Avatar
Good guys said 4 gauge because the 8 gauge isnt thick enough, and that the current wouldn't flow properly. I dont plan to upgrade though and i thought thats the only reason for 4 gauge. At good guys i would spend like 110 just on wiring and 180 with installation. I went to a different shop and they said 100 with 8 gauge earthquake wiring kit. The last shop just oppened and said they would give me 130 for 5 windows tinted with warranty and 40 for the installation with 8 gauge wiring, 7 dollars more for the 4 gauge. What do you guys recommend and y. Thanks for the help and ANY advice or comments help
Old Apr 29, 2004
DizWikedCivic's Avatar
i can do your installation for 35 bux if you come down to san jose
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
