I got a problem....
Old Apr 20, 2004
MisterTinkerTrain's Avatar
Proud Protaganistic Propagandist
MisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trusted
I got a problem....
I just got my car back from being repaired from a couple accidents and my head unit cuts out every so often...lemme explain...
It happens more when I have the music up loud, but what will happen is the speakers cut out and the head unit keeps playing liek nothing happened. Only way to fix it is to turn off the head unit then turn it back on, and lower the volume.
I thought it was the HU so I went and bought another one, and this new one does the same so I know it isn't the HU.
I'm thinking maybe there is a short somewhere or maybe a back ground. Any ideas on if that would do it or where it may be?
I have a simple setup just the HU and the 4 speakers, nothing special Running a Pioneer HU with Pioneer speakers.
I have noticed my passanger 6.5" speaker kuz sounding staticy so I wonder if maybe when the door was removeed they spiced the wire, so I will be looking there tomorrow. Any feedback is welcome.
Old Apr 20, 2004
jackscivic's Avatar
jackscivic will become famous soon enough
sounds like a fraied(sp) wire or one that is half broken. maybe it does that with the volume bc once its loud enough it rattles the loose wire and makes it cut in and out. also check the factory wireing harness, not the side that comes off the headunit. look inside and make sure inside the harness is tight. as far as i know thats all it could be. hope i helped
Old Apr 21, 2004
rinsincivic's Avatar
rinsincivic is an unknown quantity at this point
sounds like you got a speaker wire grounding out somewhere
Old Apr 21, 2004
MegaHurtz's Avatar
^^ I was gonna say the same thing, but I don't know if that would make sense seeing as the problem goes away when he turns the deck off and on
Old Apr 21, 2004
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Did you check and see if any of the pins in the deck harnesses are bent? That can cause a static/distortion sound.
Old Apr 22, 2004
I haven't had the time to check anything....but like I said I bought a whole new deck and had to rewire it and everything looked ok as far as within the dash area...I'll prolly check again, I'm heading to my dad's tomorrow to take car of looking through everything. Hopefully I can find the problem I was just hoping I had a problem that others ahve had and know how to deal with right off. =)
My best guess is there is a short and the headunit kills the signal to all speakers to keep from frying itself and\or the speakers.
Adam925
Nov 19, 2019 10:56 AM
woodsjd1
Apr 5, 2014 03:53 PM
SeanCZ06
Oct 18, 2012 05:45 PM
yamahamaxim700
Dec 29, 2011 09:35 PM
22Scout
Mar 29, 2011 02:02 PM
