Eclipse Deck Flashing
Old Apr 7, 2004
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I just got an Eclipse 8443 deck, installed it and it works great. However, when I have the head lights on the deck flashes every few seconds, it gets pretty annoying. The problem goes away when I turn the headlights off. Could I have used the wrong illumination wire? Thanks
Old Apr 7, 2004
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
check the dimmer **** where your gauges are, i have a 8053 and i had the same problem, my dimmer was like 3/4, so i set it to full brightness and it took care of the dimming.
Old Apr 7, 2004
Subrage's Avatar
Subrage is an unknown quantity at this point
had the exact same problem, same solution with the same deck
Old Apr 7, 2004
LudlamTheory's Avatar
i boogie for the raindrops
ok. **** is potentiometer on a 12v line. deck's dimmer settings respond to voltage ranges, for example (these arent the exact numbers) 10-15 volts, full bright, 5-10 volts, mid bright, 1-5 volts, low bright. if ya got it on like 3/4, the car's voltage fluctutions from 14.4 volts to 12.5 volts are making the deck think its going from range one to range two.
btw, i just made all this up, but it makes perfect sense
EDIT: except the potentiometer stuff... i know its a potentiometer, i just dont know its functions in this specific application =)
Old Apr 7, 2004
fonto's Avatar
The LA Clipper
...did you stay at a Holiday Inn Express last night?
Old Apr 8, 2004
huh?
Old Apr 8, 2004
fonto's Avatar
The LA Clipper
You've never seen the Holiday Inn commercials???...err...nevermind
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
General DIY
Sep 25, 2015 08:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Mannimarco
Sep 7, 2015 10:01 PM
