Do I need another Door Lock Relay Module??
Old Apr 7, 2004
Al_ics's Avatar
Al_ics is an unknown quantity at this point
So I bought actuators and a power door lock relay from Ebay..
I installed the driver side and hooked up the wires..plugged the relay into my Ungo alarm,..worked like a charm...
So 2 days later i decide to finish the passenger side...hook up everything again..and worked..tested it a couple of times...
Now when i was cleaning up ...i decided to test it again...and then nothin...the alarm is working but the locks arent working?!?! when the relay was working it would make a clicking noise...but now its not?!?
It is a Black Widow Door Lock Relay Module...on the diagram it says to use a 15A fuse when connected to 12V source...
But it came with a 10 fuse...
Does anyone know wat happened?? Do i need another relay module??
Old Apr 7, 2004
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
am not familiar w/ doorlock modules, but i usually use two bosch type relays and manually wire them in reverse polarity.
can you show me the diagram or list them, maybe i show you the right direction.
Old Apr 7, 2004
Al_ics's Avatar
i'll list the diagram tommorow...
but i was wondering if using 10A fuse instead of the 15A screw up the relay??
Old Apr 7, 2004
Change's Avatar
Change is an unknown quantity at this point
Is the fuse blown or intact?
Old Apr 7, 2004
Al_ics's Avatar
that was the first thing i checked...and the 10A fuse was intact...
Old Apr 7, 2004
profuse007's Avatar
Senior Member
no, the fuse doesnt change the relay issues
Old Apr 7, 2004
Al_ics's Avatar
DIAGRAM LIST
White- ground
green- Lock
Blue- Unlock
Brown-Ground
Violet- lock and unlock-->use 15A fuse and connect to +12V
then the three pin door lock harness( which i plug directly to my Ungo Alarm)
Green- lock input (-)
Red- +12V
Blue- Unlock Input (-)
Old Apr 7, 2004
Al_ics's Avatar
hey profuse...could you explain how use bosch relays?? looks confusing
Old Apr 7, 2004
profuse007's Avatar
Senior Member
use this diagram to for hook up
Old Apr 7, 2004
profuse007's Avatar
Senior Member
here it is
but if youre to use the diagram below, then you need output wire of unlock/lock from ur UNGO unit.
let me try to understand ur diagram b4 jump into something else.
Old Apr 7, 2004
profuse007's Avatar
Senior Member
Originally posted by Al_ics
DIAGRAM LIST
White- ground
green- Lock
Blue- Unlock
Brown-Ground
which one of these have choices of hooking up to? and which of the wire are instructed to do so?
Red- +12V
Old Apr 7, 2004
Al_ics's Avatar
the diagram list i showed is the micro relay...
i dont have the diagram list for my ungo alarm cuz i lost it
i think i might have short circuited the relay?!? i dont have multimeter to check it though...
Old Apr 7, 2004
WhiteRabbit's Avatar
use a multimeter to check the alarm output, could have fried the internal relay
Old Apr 8, 2004
Al_ics's Avatar
^^so the two possibilities are:
Relay output on my alarm is fried (alarm is still working)
OR
Micro relay fried...
guess i really need a multimeter...shhiet
Old Apr 8, 2004
Al_ics's Avatar
hey profuse...
so for my alarm's relay output theres three wires..
Green- lock input (-)-->goes to 86
Red- +12V---->where would i connect this to on the bosch relays--> on 87?!?!
Blue- Unlock Input (-) --->goes to 85
Old Apr 8, 2004
profuse007's Avatar
Senior Member
test those three wire. if the unlock and lock give you neg when you hit the remote, then hook it up to where it say alarm output lock and unlock.
iono what that other 12volt wire comin from ur alarm unit. its not needed.
let me check w/ the ungo site for installation manual
what model ungo is this?
Old Apr 9, 2004
Al_ics's Avatar
^^Alrite everything has been solved...i fried the micro relay somehow...so i just bought another one for 7 bucks and now i gots the power locks...
Thanks for all your help profuse...
Old Apr 9, 2004
profuse007's Avatar
Senior Member
np, you solved it urself.....
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
h4ldol
Jun 3, 2015 03:26 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
