Most power on stock alt & batt?
Originally posted by MTFlyBoy
tfna - watts has everything to do with amp draw, P=IV where P is power in watts, I is amperage in Amperes, and V is voltage in volts.... when the volts can only go up to about 12 the only way to increase the power is to increase the amp draw
yeah I have a Class T amp that puts out 345 watts at 13.3 Volts with a 30 amp draw and It replaced a Class AB amp that put out 380 watts at 14.4 volts with a 40 amp draw.I noticed a huge difference especially with lights dimming and stuff and the fact that the amp never heats up really. compared to my AB amp that would literally burn you after 30min of high volume.
Those Plastic Blaupunkt class T amps rock!
well that class T amp I had draws 36 at max power,which as most people are sayign is rarely achieved. these are the specs on my amp
Full Power: 36 amps
33% Power: 8 amps
10% Power: 4 amps
Idle Power: 1.5 amps
Full Power: 36 amps
33% Power: 8 amps
10% Power: 4 amps
davidarenberg
May 16, 2015 08:45 AM
Supramk3
May 11, 2015 07:55 PM
cloudguy
Apr 28, 2015 05:02 AM
SSMatey
Apr 13, 2015 06:09 PM
