Amp Wiring Question
Old Mar 31, 2004
harvichi's Avatar
harvichi is an unknown quantity at this point
Amp Wiring Question
I know this may be a stupid question to some, but I believe there is no such thing as a stupid question. I have two 12” 4ohm subs and an amp that I want to run at 1ohm. The following picture is how it should be wired up, correct me if I am wrong. I know how to hook up the wires from one negative terminal to the other negative terminal on the same sub. What I can’t get straight in my head is how to split the wire running from the amp to the negative terminal of each sub (this would be the top wire line in the picture). I doubt that the wire is spliced but I just can’t figure it out.
Thanks
Old Mar 31, 2004
MegaHurtz's Avatar
Looks aight to me, but check out this page, it will help you out as well:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old Mar 31, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Simply put you are connecting all the negatives together to the amp (-) and all the positives together to the amp (+).
You must have a pair of 4 ohm DVC subs for this to work as shown.
Most likely you will have two wires coming from the amp, one connected to each box terminal for each sub. So say two pieces of wire about 6 ft long. Then inside the box you will have 2 wires again per sub, one to each coil. So say 4 pieces total about 2 ft long (one wire for each coil).
Old Mar 31, 2004
harvichi's Avatar
Regularjoe
So what I understand from your post is that you can set the box up as one of the following. Am I correct?
Old Mar 31, 2004
Regularjoe's Avatar
Both are correct ways of setting that up. Both will give you the same results. The determining factor is if the box has one or two terminal cups.
Old Mar 31, 2004
harvichi's Avatar
^ Thanks for the help
Old Mar 31, 2004
Konger's Avatar
Konger is an unknown quantity at this point
Correct me if I'm wrong but wouldn't that only give you a 2ohm load unless you had dvc 4ohm like regularjoe said. To get a 1 ohm load with two 4ohm dvc you would need to add resistors in your set up I would think.
Old Mar 31, 2004
harvichi's Avatar
ya they are JL Audio 12" W3v2's, which are DVC as far as I know
Old Mar 31, 2004
SeCosCiV's Avatar
Pimp Juice Distributor
From: Dallas, Tx but now Virginia Beach, VA 'cause of job...
SeCosCiV is an unknown quantity at this point
Actually when using 2 4ohm subs, to be able to run em at 1 ohm you have to make sure the amp has a built in flux capacitor. Then you can just route the power wire directly to it.
Tedverseti
Apr 23, 2020 01:45 PM
roverben
Jan 21, 2019 05:16 PM
jackoncruzpr
May 24, 2015 12:24 AM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
