indash screen canopy...cover thingy
Old Mar 15, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
yah so i know i have seen this on here b4, but i couldnt find it anywhere. i am thinking about putting a screen in my center dash piece, where the stereo is, and then relocating the stereo, but i am stuck on how to kill the glare. so i thought about making sort-a like a frame or an overhang off the dash with fiberglass, i think that derek has this done on his car but i may be wrong......i have seen this on someones car b4........any help on how to build it? I was thinking about going and getting some thin plastic sheet cut it to the shae and then fiberglass ontop of it and around ti to get the shape i want then paint.
if not will tinting my front window kill some of that glare (i know it is illegal), but ohh well it aint illegal if you dont get caught!!!!!!
Old Mar 15, 2004
TheArkitekt's Avatar
TheArkitekt is an unknown quantity at this point
i'm working on this mod as well. the glare is something i dont worry about to much, since im in NW ohio and its uaully cloudy and raning here . as far as installing the screen there are several ways of doing it. the easiest way i can think of is mount the screen from the reverse side, this will take some fabrication work, so you may want to find some light weight alumnium. once its attached, fill the gaps with bondo. i know this sounds cheap, but its the best way to make the screen look stock. once all the seams are bondo'd and sanded down spray the whole piece with high quality black paint. the only hard parts of this project are keeping the screen straight when mounting it and making sure you dont spay the screen or buttons. i havent started on mine yet, im still looking for a good quality touch screen to hook up to a computer that im also cramming back there. but once i start ill make a how-to and post it. if you have any questions before then pm me.
Old Mar 15, 2004
forgot to add the shield part. i was going to make a slide out shield that was made to match the air vents and would retract into it when not needed. something made out of simple plastic should work fine. just mount it like a drawer to slide in and out
Old Mar 15, 2004
nunzio42's Avatar
hmm not a bad idea.....i will have to think of something and draw it up.....anyone know where to find pics of that setup i have seen on here with a big *** screen in the center with the covering around the top?
Old Mar 15, 2004
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
i dont think dereks has a canopy or overhang, but rather, i think its recessed into the dash, and that it doesnt follow the curve and angle of the dash.
Old Mar 15, 2004
nunzio42's Avatar
maybe anyone got a pic of this?
Old Mar 15, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
go to derek's member's ride page. Its on there. He used, if I'm not mistaken, a 10 inch screen, and relocated the A/C controls as well. And its recessed, and it mounted vertically square, meaning it does not follow the dash line, rather its level and square along its vertical axis.
Old Mar 15, 2004
LudlamTheory's Avatar
i boogie for the raindrops
old pic of it unfinished... never took a new pic of it, and im lazy
Name:	headunit relocation.jpg
Old Mar 16, 2004
nunzio42's Avatar
i like the headunit install.....i am curious to see what it looks like cna u please take a pic of it for me? thanks i would greatly appreciate it.
Old Mar 16, 2004
nunzio42's Avatar
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
Cam Diaz
Sep 28, 2015 08:34 PM
Jrosa
Sep 14, 2015 08:24 PM
naokigoffi
Aug 30, 2015 06:19 PM
