Home Amp
Old Mar 14, 2004
fonto's Avatar
The LA Clipper
Home Amp
Where can I find quality, low-priced home audio amplifiers? Are the plate amps from parts express any good?
Any other places to buy home amps for cheap? Any amp suggestions?
thanx
Old Mar 14, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
http://forums.audioreview.com/
http://www.hometheaterforum.com/htforum/index.php
Both will have more info than you could ever realize. Many use Tempests or the Shivas for home theater subs. I know many talk about the plate amps from parts express, but I dunno the exact ones they talk about. Poke around those sites some and you should fine everything you need to know.
Going to try something like this?
http://www.klone-audio.com/ (look at the 12 dancing shivas and mini-me)
Old Mar 14, 2004
alex053's Avatar
i saw a set up like those shivas but with eight 18's it was rediculus....
Old Mar 14, 2004
fonto's Avatar
The LA Clipper
...yeah, I was the one who posted that pic here about a year ago
Old Mar 15, 2004
dru106's Avatar
ThE CoRRupToR
You should come to downtown. Theres home amplifiers for cheap!!!
Old Mar 15, 2004
fonto's Avatar
The LA Clipper
Yeah, I would like to check out downtown one day.
Old Mar 15, 2004
Regularjoe's Avatar
What are you planning on doing. I'm assuming you wanna take the 4 old subs and do something cool for the home theater.
Old Mar 15, 2004
AlpineCivic's Avatar
I made a ported enclosure for an Alpine 15" Type-R using the same enclosure specs I used for my car and it rocks. I used 2 of the plate amps from Parts Express (1 amp per Voice Coil).
Old Mar 15, 2004
LudlamTheory's Avatar
i boogie for the raindrops
check a website called musiciansfriend.com for rack amps. mainly pro audio useage but im 100% sure theyre usable for other things
Old Mar 15, 2004
Ed's Avatar
Ed
I have used a couple of those Parts Express plate amps in my home theater setup. try posting at http://www.pesupport.com/cgi-bin/config.pl They are pretty easy going. What sub are you using? You can also get some stuff pretty c heaply at www.apexjr.com
Old Mar 15, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
look into making your own equipment, small payout up front, big payoff in the end!
Old Mar 16, 2004
problem with creating an amp so large by hand is the heatsink. youd have to take the heatsink off somehting else and retrofit it. youd be surprised how much heat 1-2 kilowatts of class a/b power puts out
Old Mar 16, 2004
fonto's Avatar
The LA Clipper
I was thinking of putting one of my Shivas in about a 2 cube sealed box with one of those 250 watt amps. It seems like it will be a fun project if I go that route.
Old Mar 16, 2004
if i were you id still go with the pro audio amp... you could power all 4 with a 200-300 dollar amp
Old Mar 29, 2004
shmik1's Avatar
if you get a plate amp from parts express can you wire up more than one sub series/parallel or only 1 amp per voice coil?
Old Mar 30, 2004
shmik1's Avatar
nevermind, i emailed parts express, so basically its just like a car amp, i assumed since i saw a post that said he used 1amp per voice coil that there might be a problem using 1 amp for 4 voice coils..
Old Apr 7, 2004
shmik1's Avatar
http://www.partsexpress.com/pe/showd...number=300-804
I bought this amp and a Type S 2ohm + 2ohm 12" from hookedontronics.com and a $30 12" clearance box from K's Merchandise and i just got it all setup last night, well i had the amp wire for a while since it came in b4 i got the sub i was going to buy a sub locally but found the type S for $104 shipped from hooked on tronics, and this setup sounds great!!!
i have no complaints at all.
I was even thinkin about if/when i go w/ a single 12" in the car i might buy a 500W plate amp for my Type R's.. possibly for our system in the basement.
GolNat
Nov 27, 2018 03:32 PM
Mc7602
Sep 17, 2015 02:01 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
