Speakers
Old Mar 2, 2004
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
Speakers
I checked out crutchfield to see wut speakers would fit best in my car (2003 coupe) and they only gave me one 6x9 to choose from and only like 8 6.5's. Are these the only ones i can use in my car or will any 6x9 and 6.5 fit in the speaker locations?
Old Mar 2, 2004
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
crutchfield finds speakers that will easily fit in the stock locations.
any 6.5" will fit, but a lot of 6.5" speakers will need a spacer and/or modification to the door for the speakers to fit.
same goes with the 6x9", a lot of them are too deep to fit in our cars because there are trunk springs that get in the way.
search the forums for other 6x9" speakers that fit, i know people have put in speakers that are not found on crutchfields site that work.
Old Mar 3, 2004
i tried searching for some other 6x9's in the forums but all i saw were infinity and rockford fosgate...and i am lookin in the alpine or pioneer direction...wut is the mounting depth for the 6x9s?
Old Mar 3, 2004
slick's Avatar
that little dude
i honestly dont know what the max depth is for the 6x9's. when i used to have rear speakers, i had a bracket made that fit the 6x9" opening, and i put a 6.5" in there instead, you'll probably have better luck doing it that way.
Old Mar 5, 2004
dragoon's Avatar
IMO the rear 6x9's arent worth your trouble. If you need bass, get a sub. If you need SQ, get some nice 6.5's up front. I got some $20 best buy Pioneers running off deck power in the back and RF HPC2206 6.5's up front that are amped. My Pioneers didnt need any modification, and my RF's needed like a 1" spacer and some minor drilling (really not a big deal) to fit. I think in the end, getting the speakers you want (at least in the case of the fronts), and then eyeballing the install when you get them works fairly well.
Old Apr 20, 2004
oh ok cool....so then will pretty much any 6.5" fit in the rear deck with a bracket or whatever u need? is there much depth difference in the 6.5 and the 6x9s?
Old Apr 26, 2004
does anyone one here have 6.5s in the rear instead of 6x9s? and will most 6.5s fit in the rear with a bracket?
Old May 21, 2004
dan502's Avatar
dan502 is an unknown quantity at this point
I have 6.5 infinity kappas in the back, and no, the adaptor plate didn't fit, so only two of the screw holes lined up, so deeper bass makes them rattle pretty bad.
Old May 21, 2004
oh ok well i'll see if i can get them custom fitted by a local audio shop
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
