parking brake lead on in dash dvd
ThE FaMiLy SeDaN
it says that the grass green (-) lead mst be connected to the parking brake so that when engaged monitor will work and when disengaged the monitor will not work... the icon is labed by a (-) so im guessing if i just grounded out the parking brake lead that it would work all the time???
http://www.teamclarion.com/sharedweb...56cc500633c5e/$FILE/VRX935VD_Eng_Inst.pdf
bottom of page 72 on above link... help me out im not gonna drive w/ dvd on but id like for my friend to watch while im driving or watch w/o me having to have parking brake on.. what would be a way around this?? grounding out? tappin on to power wire?
riley
riley
ThE FaMiLy SeDaN
yeah butim saying to not have to do that... im thinking since it says (-) lead i can just ground it out.... and it'l think its "parked" all the time... idk.. its just looking for a signal so if i give it the desired signal it woudlnt know anybetter. i just dont want peeps pulling my ebrake "one click" while drivin
riley
riley
ThE FaMiLy SeDaN
whered u put brain? im gonna use manta or w/e its called install kit.. that i already have. but idk where to put the brain.
riley
im guessin since its all self contained i just connect like reg headunit.a dn just put PS2 rca's into the a/v in and then im done..
riley
i put the brain under the pass. seat and the ps2 under my seat. make the av inputs face the back so if you want to plug something in quickly (a video camera) u can do it easily. and i got the ps2 facing the back seat with the inverter infront of it. just a warning dont let the vents blow hot or cold air on the screen too much it will put moisture in the screen.
ThE FaMiLy SeDaN
i dont use A/C like ever.. and i hope the ps2 will fit under seat considering i have dc5 seats... idk...im thinking ps2 with drawer opening towards my feet.... then inverter behind the glove box. hidden (hard wired into accy (cig lighter) brain mounted under passenger seat (boltedinto seat so people dont kick it.. and i can always feel around to plus ish in.. i dont have vid camera... so once i plug in w/e i'll be good to go... i might actually put brain in dash somehwhere cause arent the "speaker" wires all coming off the brain.. and all the "speaker" wires r located in the dash.....
riley
riley
you just have to run speaker wires, constant, switched,and any cables to the brain, its not too bad just dont turn on the car with the seat out or you'll throw a airbag code.
ThE FaMiLy SeDaN
ima just put brain in dash prolly idk. i know about seats tho and i know howto reset... idk i just dont want brain overheating and when i have sex in the car i move seats up and i dont wanna step on brain.. so im thinking in dash. like behind glove box or... in center console idk
Not sure of the size of your brain but the Alpine brain i have, i mounted in the spare tire well. But i did need to buy an extension cable so it would reach from the deck to the brain.
McLean
Jun 13, 2015 10:32 AM
Srudet
Jun 7, 2015 09:34 AM
