wiring question
Old Feb 6, 2004
perry's Avatar
perry is an unknown quantity at this point
Exclamation wiring question
okay im wiring my amp in.. and it wont power on. my friend says its because the "remote" isnt wired.
what the hell is the remote, and how do i wire it to my stock head unit?
Old Feb 6, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
Let me get this straight you are using ur stock Head unit if im right you cant hook up amp to stock head unit, why cause stock unit dont have rca jack. but correct me if im wrong.
Old Feb 6, 2004
You CAN still use an amp with the stock deck, provided the amp has speaker level inputs.
The remote wire is a power wire that goes from the stock wire harness behind the deck to the amp. It turns the amp on only when the car is on.
Old Feb 6, 2004
kalipnoi's Avatar
kalipnoi can only hope to improve
if you bought a gauge kit it would already have a remote wire. it connects from the amp to the head unit. i think its a blue and white wire thats connected to the head unit that you need to tap into. just connect them up and thats it. it will power up your amp when you turn on your head unit. i made the same mistake when hooking up my first system. its hella easy to fix.
Old Feb 6, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
With a stock HU there are no remote lines or RCA outs.
You need to run the remote wire to your ignition wire, or your cig lighter + wire.
You can use a line output converter to make RCA jacks, or if your amp has speaker level inputs you can use those.
Old Feb 7, 2004
tfnaaf's Avatar
BLDNPSI Mod
^^^ nod
Old Feb 8, 2004
perry's Avatar
thanks guys... i did some more research on it... its what tells the amp when to turn off...
you can wire it to anything thats only powered when the car is "acc" or "on"
like the power outlet/cigarette lighter
also...
this is what i did... i spliced the rear 6x9 spearker wires to my high-input adapter that came with the amp... and just ran it like that.
Tedverseti
Apr 23, 2020 01:45 PM
juror
Jun 9, 2015 02:15 PM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
klam
Nov 16, 2001 03:36 PM
