rubberized undercoating
Old Jan 30, 2004
doubledeuce2k2's Avatar
can anyone tell me how much one can will do? i've got some fatmat on my doors already, but want to add some more deadener into the hard to reach areas, and this seems like a good way.
also how much should it cost? i looked at expanding foam and see it's about $5, but i dunno about this undercoating stuff. thanks for the help.
Old Jan 30, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
expanding foam (great stuff brand found at walmart, lowes, homedepot) should be around 3.50, rubberized undercoating (mayhyde brand(same co that makes bondo) is about the same price at autozone/advance/pepboys/etc
Old Jan 30, 2004
one can of the rubberized undercoat i mentioned will do about up to 20 sq ft., depending on how thin or thick you apply it
Old Jan 30, 2004
I used a can to spray all four wheel wells. Make sure you get the bondo paintable one, because the other kind smells terrible and doesn't go away!
Old Jan 31, 2004
LudlamTheory's Avatar
i boogie for the raindrops
i used one whole can to do my rear bumper
i took teh bumper off the car and sprayed teh backside because it was rattling against teh frame
then i used one more can to do teh front doors. i like thick thick rubbery coats on my ****
Old Jan 31, 2004
WhiteRabbit's Avatar
one can of the coating for me was about equivalent to doing my entire door in half a layer of dynamat regular.
Old Jan 31, 2004
but it was the ENTIRE door skin, not just patches in a cluster**** everywhere, like deadening usualy is for me
Old Feb 1, 2004
what would work best on the actual panels inside the car? i want to stop rattling, but also want to lower road noise at the same time. once it warms up i'm gonna hit just about every panel with one or the other (undercoating or foam) plus i'm gonna foam up the trunk lid (fatmat didn't hold on there for some reason).
on a side note, does anyone elses door lock rattle? my rear ones don't, but i noticed lately that both the front ones rattle when i hit bumps.
Old Feb 1, 2004
Have you been to b-quiet.com? They have a foam padding called v-comp, but you need spray glue to stick it down. It doesn't smell, either.
For the door locks, you can put a small piece of ept foam where the lock slides in it's hole. You'll see what I mean once the panel is off. Works great, unless it falls out.
Old Feb 1, 2004
yeah, i used paper towels and duct tape to prevent my doorlocks form rattling.
as to removing rattling from other parts of the car, Im a fan of buying 20 cent bath towels from walmart and stuffing them between whatever is rattling, then replacing the panel.
works like a champ!
dlg1985
Jul 23, 2017 10:03 PM
Sep 27, 2015 11:33 AM
Laucard
Sep 18, 2015 07:11 AM
Klame9420
Sep 7, 2015 10:03 PM
DerbyDad03
Jul 27, 2015 11:34 AM
