Center dash controls backlighting
Old Jan 16, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
Question Center dash controls backlighting
just wondering how the a/c and heater controls are lit up on my '01 LX coupe. I want to change them from amber to blue and was wondering if it is simply a bulb, bulb cover or whatever to change out. Also if someone could provide a link to removal of the center dash cluster (i know it is on here somewhere) thanks.
Old Jan 16, 2004
doubledeuce2k2's Avatar
there is a tiny bulb inside the control button. you pop the little A/C button off and then you can kinda see it. you can either put LED's in there (great look, but a lot of work) or put gel covers over them (easy and works, but light gets very dim).
http://www.7thgencivic.com/modules.p...howpage&pid=53
^^^ link to console removal. post pics of whatever you do. BTW, that is in the DIY area, on the left column of the page (every page, in fact)
Old Feb 7, 2004
pheaton's Avatar
A descendant of 2k1civic.com
I did it the cheap way. I took it apart. Behind the buttons and behind the **** areas there is orange tint which can be removed. I replaced the orange tint with blue, which actually came off of a tranparent blue folder that I picked up at Office Max.
Just use the old orange peices as patterns to cut out your new blue ones. I had to put 3 and 4 layers of the blue folder on, because 1 layer made the lights look white, and it took a few layers to get the blue color I wanted. I used rubber cement to hold the layers together and to attach to the console peice. I'm happy with it and it was a cheap way to do it. Costed me under a buck for the folder.
Old Jul 29, 2004
glovas's Avatar
glovas is an unknown quantity at this point
Hey the folder idea sounds good, and cheap, I have a 2k2 sedan will that work on mine
Old Jul 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Yes. But you know, if you have a soldering iron, it's pretty much the same amount of time to LED the light as to filter it. It's a personal preference thing at that point, but the amount of work is about the same, might take a FEW minutes more.
Old Jul 29, 2004
glovas's Avatar
The led sounds very hard, and do they last. And the sock bulbs what are they 168s or 194s
Old Jul 29, 2004
TeLLy's Avatar
If done right the first time, the LED's will last a very very long time - they don't burn out like conventional bulbs. The lighting behind the console is not from 194 or 168 bulbs. It's from tiny incandescent bulbs in twist sockets, which as far as I've seen are not available anywhere outside of a Honda dealer.
Old Jul 29, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
Some LED's could last up to 30 yrs, there is no filliment like a bulb. They are diodes. Even a cheap LED could probably last 5 or 10 yrs. An easier way to do the LED is buy a 3 pack at auto zone or best buy. $6.99 and it already has the resistor on them. To get a wider light band, I sand mine down.
Old Jul 29, 2004
glovas's Avatar
what grit sand paper, and how far down
Old Jul 29, 2004
I used 200 grit, and sanded down far enough but not too far as it would hit the diode. if you keep looking at it from the side you can tell. It is about half of the LED that is sanded off but no more than that.......To give you an idea, if you don't sand it and put it under the gauges, it will light up 1 number or so, but if you do sand it, it will light up about 3 numbers.
Old Jul 29, 2004
TeLLy's Avatar
Or if you have a Dremel and that tiny little sanding drum attachment for it, use that. I do, and it's much faster. It also helps to shave the sides...that way you can actually get a 5mm to fit.
Old Jul 29, 2004
MegaHurtz's Avatar
Does anybody make preassembled light kits for 7th gens?
Old Jul 29, 2004
go here.. its basically a diy for changing your center console colors http://www.99accord.com/index.asp
Old Jul 29, 2004
TeLLy's Avatar
And he sells the LED kit too. Not preassembled though.
Old Jul 29, 2004
slappyhoohah's Avatar
i want to do this so bad but seems kinda confusing (i know, im slow)
i just dont really understand where you connect the wires, i've gone over the diy a million times
Old Jul 29, 2004
I did a complete rewire with leds and tapped into the parking light wire. There is info in my glow needle diy in my sig. It has a paragraph of how leds work and stuff.
Old Jul 30, 2004
glovas's Avatar
slappyhoohah: Ive done the same thing,and I pintted it out just doesn't make since, maybe I should just do it, and read along. this is something Ive wanted to do for a long time.
Old Aug 17, 2004
Benzboy429's Avatar
Benzboy429 is an unknown quantity at this point
i wanna do it too my radio is blue...if there are any takers it's cool wit me
mjdiaz89
Jun 21, 2016 09:26 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
