Question on wiring a system
Old Jan 13, 2004
Fuehrer2003's Avatar
Fuehrer2003 is an unknown quantity at this point
Question Question on wiring a system
I was going to put a system in my 2k3 coupe. I was looking at a wiring diagram and you run a power cable off of the postive terminal of the battery. Do you do anything with the negative battery terminal? I know that you run ground wires from the amp to the body of the car to ground. The only reason I ask is I was looking at wiring for a system and i am going to use stinger products. Why do they sell a negative battery terminal if there is no use for it?
Old Jan 13, 2004
doubledeuce2k2's Avatar
maybe to improve factory grounds? or else just to make money
don't run the wire all the way back to the battery, you only need about 2 feet of ground wire really. i think you know this, but just wanted to be reassured.
Old Jan 14, 2004
Thanks
Tedverseti
Apr 23, 2020 01:45 PM
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 3, 2015 02:17 PM
