Having some weird problems
Old Jan 4, 2004
03blueSI's Avatar
03blueSI is an unknown quantity at this point
Today I started working on my car in hopes of eliminating some noise from my system. All I did was to try to find a better ground for my Head Unit. Yhis didn't help so I disconected the power connector from the head unit and tried to move my head unit to the hatch to test and see if it was a problem with the head unit wiring but when I re-connected the head unit to the power connector I got no power, so I check the fuses for the head unit and it is fine. Then I notice my power door locks are only working when I have the ignition on so I check the fuse for it which is fine. I try the factory headunit just for the hell of it and it has no power either. I probe the wiring harness and the 12 volt + wire has no power at the connector, all of the other wires that should have power do. I am stumped on what could be wrong unless there is some other fuse I am missing that can cause this problem. The only other aftermarket thing I have installed besides stereo is a Clifford GR (Concept 550) alarm. Thanks for any help anyone can provide.
Old Jan 4, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Check all your fuses...including the ones under the hood. One labeled "backup" may be the culprit.
Old Jan 4, 2004
03blueSI's Avatar
cool, thanks I'll check that one. Another person on another forum mentioned it as well. Hopefully it will work
Old Jan 4, 2004
03blueSI's Avatar
Thanks for the help. It was the backup fuse
Old Jan 4, 2004
tfnaaf's Avatar
BLDNPSI Mod
haha i overlooked that fuse and spent hours one day trying to figure out WTF was up. I even posted here about it and was pointed out by another member. Good catch Mystic3030!
Old Jan 5, 2004
2k1civic's Avatar
2k1civic is an unknown quantity at this point
I am having the EXACT same problem..... Im so gad I found this post. I will check out the backup as soon as I get a chance.
Poopies
Apr 20, 2017 11:36 PM
mrohitredd
May 30, 2015 06:51 PM
mrohitredd
18
May 14, 2015 07:35 PM
tylerginevan
Apr 27, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
