New Pioneer Head Unit
Old Dec 31, 2003
stupidd's Avatar
stupidd is on a distinguished road
Ok, for christmas i got a Pioneer DVH-P5000MP. Plays cd's, dvd's, mp3, very nice. I'm pretty good with wiring stuff, i've done my whole system (amp, sub, replacing all speakers) up until now. I dont want to take it to a professional and pay $50+ to have it installed, because i know how to do everything... almost.
1. Now it says i need to hook the unit up to my parking brake.... why? is this a necessity? If so, where can i find a parking brake wire closer to the head unit?
2. Where/what do i run the orange/white wire to? It's labeled "ILL" and in the instructions says "To lighting switch terminal."
3. Red wire labeled "ACC" obviously this is what turns on the unit. Instructions say: "To electric terminal controlled by ignition switch (12 V DC) ON/OFF."
I think that might be it.... but that parking brake still gets me...
Old Dec 31, 2003
LudlamTheory's Avatar
i boogie for the raindrops
parking brake is so you cant watch movies while driving.
i cant remember whether or not you ground that wire or hook it up to a 12v+ to bypass it
Old Dec 31, 2003
stupidd's Avatar
well that makes perfect sense. that crossed my mind... but i was hopin pioneer wouldnt do that to me. oh well... easy to fix.
edit: but wait... cant people in the back seat watch movies while you're driving? or does this just affect the Front video input and not the rear?
Old Dec 31, 2003
affects front video, but its easier to bypass than it is to install
Old Dec 31, 2003
stupidd's Avatar
so i guess i could just hook this up to the power wire or acc wire, right?
Old Dec 31, 2003
justplainbad's Avatar
Victory is Mine!
justplainbad is on a distinguished road
No, the light green parking brake wire is hooked up into a GROUND to bypass it, I install these things for a living. Think about it, you hook it into the wire that is hooked into a pin which reads ground when the parking brake is released off of the pin.
Old Jan 2, 2004
stupidd's Avatar
thank you very much. i got everythingn set up right, but now i have another problem. i've hooked my amps ACC wire through the pioneer head unit like it's supposed to be, and the rca cables. but now when i switch from cd to radio, or change radio stations, or turn on the car or turn it off i get subwoofer feedback. i think thats what to call it. i get a loud couple bumps from the sub. why is this happening?
Old Jan 2, 2004
doubledeuce2k2's Avatar
the sub bumps when the amps turn on and off... you aren't using speaker level inputs are you?
Old Jan 2, 2004
stupidd's Avatar
no, i'm using the pre amp out puts on the back of the cd player
Old Jan 3, 2004
stupidd's Avatar
the sub hits when i:
1. Turn the car on and the cd player turns on
2. Turn the car off and the cd layer turns off
3. switch from tuner to cd or visca versa
4. During that very short no-sound time when switching radio stations
these bumps have nothing to do with the cd being played or song on the radio station. they're pretty short, but kinda loud. If you're a proffesional with car audio and do a lot of installing, please help
Old Jan 3, 2004
urmystlkal's Avatar
urmystlkal is an unknown quantity at this point
means somethign isn't grounded right or you have a short somewhere. Check all connections and make sure they are clean and nothing is touching anything it shouldn't be.
Old Jan 3, 2004
stupidd's Avatar
does that sound like a ground would be wrong on my head unit, or the amp?
Old Jan 3, 2004
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
what wire from the head unit did you hook to the amp turn on wire?
Old Jan 3, 2004
stupidd's Avatar
it's a little blue/white wire coming out of the head unit that had a connector, i think it was labeled "system power" in the installation guide here it says "to system control terminal of the power amp or auto-antenna relay control terminal (max. 300 mA 12 V DC)"
Old Jan 4, 2004
that would be correctly installed
there are little modules that get rid of the turn on/off pop sound, but i also saw another guy with a pioneer deck that had the same pop sound when he switched from one source to another.
im curious, maybe its the deck
try hooking up the remote wires to the cigarette lighter +
Old Jan 4, 2004
stupidd's Avatar
i tried that, i couldnt tell if it made it any worse, but it definitly wasnt better... i have no clue what do to.
"there are little modules that get rid of the turn on/off pop sound"
what are those exactly called? maybe show me one on ebay, or give what to search for.
Old Jan 4, 2004
man now i'm trying to remember if my old pioneer deck did that... it may have. i get the noise at system turn on still, that is more the amp than your HU. but i don't get it any other time...
Old Jan 4, 2004
stupidd's Avatar
i think i'm gonna check my amps ground wire tomorrow. thats the only thing i havent checked so far... i think. i want to know more about that module, but i dont know where to start.
i may end up taking my car to the local car audio place here if i cant fix it myself. dangit.
Old Jan 4, 2004
JohnDoe's Avatar
was it a blue wire with a white stripe or an all blue wire? If I remember right pioneer has an amp turn on AND a power antenna lead. Blue with white is power antenna, it should be connected to the amp turn on which would be all blue.
Old Jan 4, 2004
stupidd's Avatar
blue with a white stripe. it says in the install guide "to system control terminal of the power amp OR auto antenna relay control terminal.
Old Jan 5, 2004
JohnDoe's Avatar
see if there's a only blue wire, if so hook it up to that one.
Old Jan 5, 2004
stupidd's Avatar
well i didnt get around to much today, it was raining pretty hard all day. but i did discover that when i turn the volume all the way to zero it makes that noise too. so i'm guess whenever my sub/amp does not get a sound signal it does that.
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
