Brutus BX1500D, KX1200.1, JBL BP1200.1
Old Dec 24, 2003
Shaggy's Avatar
Shaggy is an unknown quantity at this point
Well it is pretty easy to understand what I want to know.... which one is best? I have a KX 600.1 right now running two 4-ohm S10L7's and I am not sure if it is up to par for those subs. If you think that amp is sufficient tell me. Otherwise make your choice our tell me other choices. Thanks.
Old Dec 24, 2003
doubledeuce2k2's Avatar
L7 in 10 inch max power handling (rms) = 600W
assuming these are single voice coil, you are currently giving them half the max rated power.
if you don't like the sound, tweek the box or start deadening. it will likely do more than a larger amp will (certainly cheaper).
Old Dec 24, 2003
LudlamTheory's Avatar
i boogie for the raindrops
well. of all 3 amps, you probably wouldnt notice a difference, but personally id go with teh hifo
VNlilMAN
Feb 6, 2003 09:47 PM
VNlilMAN
Aug 29, 2002 02:53 AM
LudlamTheory
Aug 21, 2002 02:57 AM
civic510
Jun 24, 2002 12:26 AM
RichardCranium
May 11, 2002 05:35 PM
