Putting center console back on! (HU, vents)
Old Dec 21, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Since I've got my EQ and needed to make wire changes here and there, I left my center console only partially attached for a week or so. Now I can't get the ****** back on, it locks in pretty good at the bottom but i need to push HARD at the top to get the inserts in their slots to lock, and even when I do get one side in and try working in the other it eventually pops out from pressure. I've checked behind to see if any wires are stopping it but i guess not. Any of you guys have problems getting it back in? Don't know what information would *help* me but if you have any that would be nice, thanks.
Old Dec 21, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
check the clerance on the back of the eq.
Old Dec 21, 2003
syndrome's Avatar
The EQ is where my ashtray was right now, its not in the console itself.
Old Jan 15, 2004
razorsedge's Avatar
razorsedge is an unknown quantity at this point
i hope its not too late to help...
Hey, I had the same problem on my 2004 when I installed my new Alpine HU. Look closely at the ducting that the vents mate to. The alignment between the ducting that is in the dash and the actual vents themselves that is part of the center piece you have to pull out for the install is critical. Thats usually the area that binds. The ducting in the dash likes to sort of close up or collapse when you remove the center piece that has your headunit/ pocket in it. Simply use your fingers to reform the dash ducting and align very carefully and it should go together nicely.
Hope this helps!
razor--
Old Jan 15, 2004
AlpineCivic's Avatar
another thing tha might get in the way is the actual metal bar/tube going across the the car and right behind the head unit, the headunit should go under it and your probably pushing against it.
Old Jan 15, 2004
syndrome's Avatar
Actually, it was the wire that connects to the 4-way flasher plug, it would get jammed between the vent and where it connects to the direction adjusters. After I fixed that my console fit in just fine, even now with 2 DIN units installed.
mrcell24
May 19, 2015 10:02 AM
vgon24
May 12, 2015 09:16 PM
crowtoo
May 11, 2015 06:50 PM
NeoMagus
Nov 17, 2001 07:29 AM
