Infinity Speaker Fitment...????
Old Dec 12, 2003
TrippinOvaNuttin's Avatar
TrippinOvaNuttin is an unknown quantity at this point
Will the INFINITY REFERENCE 6000CS 6 1/2" COMPONENT SPEAKERS fit in my doors and in my tweeter spot in my EX?
and
Will the Infinity Kappa 692.5i (6x9s) fit well in the rear....?
I want to buy components for the front that do not need much modification to fit... and good speakers for the back so i can actually hear my music once i get my subs in... i am going to buy a 4 channel amp eventually for these speakers... but how do you think they will sound thanks
Old Dec 12, 2003
Bellz's Avatar
Ahh, the Infinity question yet again. Finally, somebody did their research.
The 6000cs and 692.5i should fit without modification. They're a shallow mount setup rather than the Kappas with their huge magnet structure.
Looking at the pic below, I would guess that the tweeters are small enough to fit in your sail panels. They may require a little modding to mount, but they should fit.
Infinitys always get high recommendations, so they should sound great. I'm considering the same setup for my car eventually. If you haven't been to Ikesound yet, check out these links. They're one of the cheapest vendors online that sells Infinity stuff.
6000cs components $105
692.5i 6x9 $98.10
Other stores:
Discount Jungle 6000cs $98.90
Buy electro.com 692.5i $99.94
Old Dec 12, 2003
reflekt's Avatar
reflekt is an unknown quantity at this point
how did u guys do the 6x9 rears for the inifinity kappas or reference?
My friend has those speakers and he had to do a different whole trunk shock setup.
im just wondering how you guys did your rear speakers? the same?
Old Dec 12, 2003
scarpones's Avatar
scarpones is an unknown quantity at this point
the 6000cs need spacers, half inch is too small and 1" is too big...if yer up for it, make .75" outta wood, or use the 1" and leave the bottom part of the door panel not connected.
and they sound awesome, the highs and mid are crystal clear...but they need a sub to make up for lack of thump
Old Dec 12, 2003
Bellz's Avatar
The Kappas are huge and simply way too big. The 693.5i for example is 3 11/16", where the stock spec is 3 7/16". It hits the springs and using a spacer up top would keep the rear deck from going back on. If you already have a sub, a set of good 6.5"s in the back do the job nicely with a 6x9 to 6.5 adapter.
You will need an adapter to mount the speaker onto, plus drill a few holes to mount that. The specs are close, but the adapter should also serve as a spacer to keep the speaker from hitting the window. The mounting depth is 2", and the 6000cs is 1 15/16".
Click the sounddomain link below to order a spacer or to look at one.
http://www.sounddomain.com/sku/SCOSAH6
Old Dec 12, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
what speaker size is the sail tweeter in our cars? I want to upgrade that. I have Alpine's in the doors, and am either going to build custom fiberglass kick-panel enclosures for those, or (if they will fit) build kick-panel enclosures for my 8" subwoofers. Either way, I want to upgrade the stock tweets, and the location is perfect. I just need to know what size (and what brands I can get just the tweeter in).
Old Dec 12, 2003
Bellz's Avatar
I can't say for sure, since I have the DX. I mounted some Pioneers in the doors in front of the door handle...works great for me.
Check out this thread for more info:
http://www.7thgencivic.com/forums/sh...5&pagenumber=2
Old Dec 14, 2003
kafyn722's Avatar
i have reference in my car all around. i love the set up, and i had to do the truck shock set-up cuz i didnt want to do spacers, i heard they sometimes can rattle. wasnt that big of a deal.
Old Apr 19, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
so the infinity reference 6x9's wont fit on the rear deck without hitting the trunk springs?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
