Speed sense wire at ECM?
Old Dec 4, 2003
speedster's Avatar
speedster is an unknown quantity at this point
Ok, I looked at the wiring diagram on this site for the speed sense wire. It says it's a white/green wire on the 31 pin connector. Well there's no wire by that color on the connector. There's a male/female plug infront of the the ECM that connects two bundles of wite. It has a white/green wire, but that's not what the diagram said. Can anyone help?
Old Dec 5, 2003
WhiteRabbit's Avatar
you are trying to hook up a tachometer? what kind of signal is it?
If it requires the pulses from the speed sensor, the wire is on the transmission, and ive got pics of its location.
but if its not that, then i cant help.
Old Dec 6, 2003
speedster's Avatar
I'm trying to disable the speed limiter. I found the wire yesterday. Thanks anyway.
Old Dec 6, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Just a warning to you....disabling your speed limiter will void your vehicle warranty if your car is still under it!
Old Dec 6, 2003
speedster's Avatar
Yeah, it runs out it like 4000 more miles. No biggie
WKD DRGN
Jun 18, 2015 07:56 AM
tmort
May 11, 2015 07:13 PM
pincookie1
May 4, 2015 12:22 PM
tkcne
Apr 18, 2015 02:33 AM
BREADFAN
Apr 15, 2015 08:58 AM
