System and HeadLights and Electrical
Old Dec 3, 2003
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
Unhappy System and HeadLights and Electrical
I have projector headlights with H1 bulbs. One night i was driving with my system booming and my right lowbeam went out and then my left highbeam went out. I got new bulbs from a great place that has a lifetime warrenty on them. The other day i was in the same conditions, driving with my system booming and my right low beam went out and then eventually my left lowbeam went out. Im getting them replaced under warrenty. Why is this problem happening. My ligts do dim when my subs hit, do you think its the constant action of the voltage going up and down to the bulbs that is caussing this? Do you think if i replace my stock Battery with an Optima RedTop the problem will be solved? any input?! thanks
Old Dec 3, 2003
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
hey, VIBRATION!!!!
Old Dec 3, 2003
doubledeuce2k2's Avatar
or you put too high wattage bulbs in.
stock is 55/60W. others will blow or fry your wires in the long (or short) run
Old Dec 3, 2003
Samari's Avatar
yes, just use regular output bulbs
Old Dec 4, 2003
NukeSilo's Avatar
im using 65 watt bulbs all around, is that such a diffrence?
CarStuff
Dec 6, 2020 12:52 PM
jtdunn4life
Oct 27, 2015 03:33 AM
SuperEF
Jun 24, 2015 11:53 PM
shaejb15
Apr 26, 2015 07:44 PM
NukeSilo
Nov 20, 2001 05:17 PM
