Fuse Box Question
Old Nov 8, 2003
salokod's Avatar
salokod is an unknown quantity at this point
Fuse Box Question
In our fuse boxes, is there a fuse for our CD Players? Cuz mine just doesn't work anymore and i tried the fuse behind the CD Player itself and that one is fine.... and i looked at the little diagram on the fuse box and there was nothing there too?
Old Nov 8, 2003
Samari's Avatar
there are 2 fuse boxes. 1 in the eigine compartment and 1 in the interior. you are looking for the one in the interior and it is below the steering wheel column. it has 2 clips holding it in. You should see the radio fuse. Also check your wiring, it could be lose or something.
Old Nov 8, 2003
salokod's Avatar
gracias
Old Mar 6, 2010
danielw's Avatar
danielw is an unknown quantity at this point
Re: Fuse Box Question
can someone provide a diagram for the 7th gen interior fuse box? thanks
Old Mar 7, 2010
danielw's Avatar
anybody?
Old Mar 10, 2010
SHOme89's Avatar
SHOme89 is an unknown quantity at this point
if you "unlock" the plastic cover thats covering the fuse panel (theres 2 dials you turn to unlock the cover, near the pedals on the bottom side of the steering wheel). On the back of this panel, there is a diagram telling you what fuses are where. THe radio fuse is on the bottom row, 3rd fuse TO THE LEFT. i believe it's 7.5amp brown fuse...but double check that diagram on the panel. hope that helps
Tedverseti
Apr 23, 2020 01:45 PM
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
smmahan
Apr 15, 2015 08:17 PM
cazminn
Nov 9, 2001 11:18 AM
