plan on plexiglass amp in trunk
Old Nov 6, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
ive seen a couple of members with their amps plexiglassed into their trunk floor. im planning on doing that this weekend but im wondering if i plexiglassed my amp it how would the amp cool? did u guys put holes in the plexiglass? what did u guys do?
Old Nov 6, 2003
reytito's Avatar
i kinda had the same question...
Old Nov 7, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
by plexiglassed, do you mean under a see thru window under the trunk floor? or did you mean fiberglassed into the spare well? i have never seen an amp encased in plexiglass, what does it look like, in a square box just kind of sitting there? if so, what would that serve, other than protecting it from dust and debris falling on it? mine is fiberglassed into my trunk, well, almost, i am still working on the finishing touches to it (final sanding, painting, more sanding, and clearcoating)
Old Nov 7, 2003
yea i ment like plexiglassed under the trunk floor. looks like the floor has a glass window with the amp underneath. i want to do mine that way this weekend but im just wondering what you guys did to allow the amp to cool. ???
Old Nov 7, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Computer case fans, or "crossflow" fans wired with a relay to your remote turn on lead so they activate when the amps go on are great for cooling. Or you could get really fancy and use electric thermometers and relays to make them turn on at certain temps.
In either scenario, if the amp will be totally encased on all sides, you should make sure there are vent holes, and use several fans in an intake/exhaust fan setup.
Old Nov 7, 2003
thanks but can you please explain how i would connect the fan to my turn on lead??
Old Nov 7, 2003
WhiteRabbit's Avatar
http://www.eatel.net/~amptech/elecdisc/amprack.htm
there ya go put the fans where the plexiglass isnt, then use computer fanguards so nothing gets on the blades
Old Nov 7, 2003
Mystic3030's Avatar
Use tap-in connectors or cut the remote lead, and splice in another wire with butt-connectors and run that spliced lead to the + wire on the fan. THen you ground the negative of the fan to the body of the car.
I prefer butt-connectors for a secure connection.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
