ignition wire has no power?
Old Oct 29, 2003
fuchs's Avatar
fuchs is an unknown quantity at this point
Question ignition wire has no power?
When i went to put in a new deck i found that my ignition switch wire has no
voltage. does anyone know how this could be? it worked fine before. is there a fuse or some
other place i can trace that wire back to?
Old Oct 29, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Check the fuses under hood and under the steering wheel.
Old Oct 30, 2003
fuchs's Avatar
i checked all of the obvious fuses. i want to know where this wire gets power from.
Old Nov 1, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
the battery?
Old Nov 1, 2003
Mystic3030's Avatar
Try checking the not so obvious fuses. The wire gets power at the fuse box under the steering wheel, or under the hood. Thats where ALL the wires in your car get power.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
CiviCKiD
Jan 1, 2002 08:02 PM
