x-over question
Old Oct 28, 2003
mattymatt's Avatar
mattymatt is an unknown quantity at this point
x-over question
I have cross overs on both my head unit and my amps. Which one do I set or do I set them both? Thanks.
Old Oct 29, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
You can set both if you want.
Old Oct 29, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
depends.. usually you would go with the better quality equipment to do the crossover.. if the one on the amp is a variable one, then use that instead.. there is more room for tweaking..
Old Oct 29, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I wouldn't set both. The more crossovers you have, he worse sound quality gets. I'd use the one on the amp
Old Oct 29, 2003
fonto's Avatar
The LA Clipper
I would use the ones on the amps. You never know how steep the crossover slope on the HU's crossovers are because they usually don't say. What if it is like a 6 db per octive x-over...you don't want to use that.
My personal preference is to go with whatever component has the steepest crossover. You can use more then one and the will cascade and make a steeper slope...but it will be hard to tell where the true crossover point is (where -3dbs is).
Old Oct 29, 2003
mattymatt's Avatar
Why is it that when I make the adjustments I don't hear any difference? The mids are getting too much bass so I set the cross over at 100hz and there was no change, I played around with different numbers and it was the same. Is there something wrong with it? I can't figure any of this out because alpine doesn't explain sh%t in there manuals.
Old Oct 29, 2003
fonto's Avatar
The LA Clipper
I bet the Alpine crossover that your talking about is on your head Unit. It is probably not the greatest crossover so you should use the one on the amps. The reason why they don't explain ish in the manual is prolly because the x-over is less then 12 dbs per octave.
Old Oct 29, 2003
mattymatt's Avatar
You bet correct, I'll have to use the one on the amps.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
