Multi amp system-help
Old Oct 25, 2003
SilverSivic02's Avatar
SilverSivic02 is an unknown quantity at this point
Hey guys I need some help. My setup so far is panasonic headunit with kenwood components up front and pioneer 6x9s in the back being fed by a kenwood 320 watt 4 channel amp. The pioneers will be replaced by kenwoods, but my question is I plan on using 2 alpine type r 10'' subwoofers with a 2 channel 600 watt amp from kenwood, how do I wire this thing in? The 800 watt amp wiring kit is installed, connected to the current amp, do I need another wiring kit?, or do I use other parts? I know more about mechanicals than wiring and ice, so any help is appreciated.
Old Oct 25, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
You use other parts.. get a fused distribution block and use a SPDT Relay to turn the other amp on. Then just wire up the amplifiers like you normally would
Old Oct 26, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
for the two amps for the subs, use a fused dist block, and then choose one amp to be "master" amp or wutever, and the other one is like slave amp. the master amp is hooked up to the head unit like normal, and then get another pair of rca cables, plug it into the master amp under aux output or output or wutever its called on ur amp, and plug those into the slave amp for input. for the remote turn on wire u cud just splice one into the other, thats wut i did and i never had any problems
Old Oct 26, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
If your HU has a "non-fading" or "sub level control" set of pre-outs run a new set of RCA's from that output to your new amp, that way you can control the subs from the HU. Is your wiring kit 4 guage? If it is, then you can just get a distro block, fused or not...doesnt really matter, and split some 8 guage to each amp. The remote turnon can be spliced...do not use a "tap-in" connecter, rather get a closed bell connector, it's like those orange twist connectors used for home wiring, but you crimp it for a solid connection. Should be pretty straight forward, maybe you have some friends that have done it before to give you a hand? Even if you don't have friends with experience, get one or two to help you.
Good luck!
Old Oct 26, 2003
thanks for all the help guys, I have a pretty good idea as to what I am doing now.
Old Oct 27, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
yeah...if u have the 8gauge kit running from the batter to the back, its kinda dangerous to use a distributor. Highly recommend running either 4 gauge, or if ur crazy enuf, run 0 gauge from the front to back, and distribute with 8 guage wire (or 4 guage if u ran 0 gauge from front to back). Then you're set!
Old Oct 27, 2003
Mystic3030's Avatar
He doesnt need 0-AWG for those amps...would be a major waste of money, especialy since it's like $6 a foot. 4 guage would be more than fine.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
