sub cut off need help...
Old Oct 23, 2003
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
ok if i keep the volume low on my subs they are fine.. once i turn it up it cuts off....anyone help me with this....
Old Oct 23, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
maybe your ground/power cables are insecure? That's my only guess. Sounds like when it tries to put too much power through it, it can't handle it, which makes me think it's an insecure connection somewhere.
Old Oct 23, 2003
WhiteRabbit's Avatar
check the loading. my guess is that youve got a 4 ohm amp with a 2 ohm load on it. maybe a 1 ohm load. at low volumes this will be fine, but at high volumes, it would cause current protect to be activated.
what amplifier, and what subwoofer have you got?
Old Oct 23, 2003
civic01vtec's Avatar
^^^^ he could be right or check ur gain......u may have that cranked to high.
Old Oct 23, 2003
I never had any problems with my install. I did it myself. Maybe I've been hitting alot of bumps in the road and something jarred ?
I have 2 Rockford Fosgate He2 subs driven by a 400 watt mono block amp. All the volumes on the amp are at around half power going through. The sound is PERFECT in my car at those volumes.
I secured all the wires back and only 1 sub works now....
EVERYTIME i get out of the car and put my hand on the door I get an electric shock. My ground is secure? I have no idea what's going on!!
Old Oct 23, 2003
is the monoblock 2 ohm stable? ohme ohm stable? are the He2's 4 ohm DVC?
if your monoblock is only 2 ohm stable, and the HE2's are 4 ohm DVC, then that would clearly explain why you are getting overcurrent.....
Old Oct 23, 2003
doubledeuce2k2's Avatar
forget the shock, thats just part of winter and has nothing to do with your problem. also do you have the bass cranked on your headunit?
Old Oct 23, 2003
Logan3024's Avatar
Re: sub cut off need help...
1. Does it go into protection mode?
2. Is the power still on (amp) when your subs cut off?
3. What kind of amp are you using, i know its a 400 watt mono block, but what kind, that could be your problem.
If all of your setting have been the same since you installed it, it would definitly have to be a problem internally in your amp.
90% of mono blocks are 2 ohm stable
ohme ohm stable?
yes, dual 4 ohm
General DIY
Sep 25, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
Mc7602
Sep 17, 2015 02:01 PM
EM2661
Sep 11, 2015 06:01 PM
redcloud
Sep 7, 2015 01:45 PM
