How do you get stock cd player out?!?!?!
Old Oct 13, 2003
crischoncbh's Avatar
crischoncbh is an unknown quantity at this point
Im trying to install an indash screen without being charged an arm and a leg at a shop...
I know how to hook up everything real easy, but i don't know how to free up the stock cd player. I took off the glove and instrument cluster to get screws lose, but i think (not sure) there is one screw in between cdplayer and ac controls!
what do i do//??
Old Oct 13, 2003
Phanibal's Avatar
Phanibal is an unknown quantity at this point
Go to the DIY section-then go to audio and there it will show you how to remove it, pretty simple!!!
Old Oct 15, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
No need to remove the glove or instrument screws. Just follow the audio DIY for removing it before you take too many extra steps.
Old Oct 15, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
since they aren't going to tell you, and yes there is a diy, pull out the cig lighter/accessory plug panel (give it a stiff tug) kinda get down and look up once that is removed, there are 2 screws up in there, take those out. then pad something such as a flat head screw driver, and slide it around the edge of the radio panel and pry gently on it, you may can get your fingers under there, provided you don't have large fingers, and pull it out. voila' you're done.
Old Oct 16, 2003
Thanks guys...i got it and got it all installed!
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
