rockford headunits
Old Oct 13, 2003
dups's Avatar
dups is an unknown quantity at this point
rockford headunits
How good are the rockford units? I was considering going with the RFX9220 with 3 5v outputs and everything, is this unit pretty decent?
Old Oct 13, 2003
alex053's Avatar
i have the 9320 and it hasnt given me any problems. the remote is great and plays mp3's.
Old Oct 13, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I'm not sure if this is true, but I've heard Rockford heads are built by Delco (the people that build audio systems in most GM cars). If so, it's probably pretty solidly constructed. I've never been able to find one in a shop to listen to.
Old Oct 13, 2003
dups's Avatar
I've got a shop near me that has em', they seem alright, I'm probably still gonna go with the nakamichi deck I wanted, but this shop is run by people I know and trust with audio stuff and they strongly suggested I consider the rockford units, but I think I'm stuck on the nak's.
Old Oct 14, 2003
alex053's Avatar
the old ones were built by delco. with the black faces and more ruberized buttons. the new ones are built by a company whos name you know not for stereos but another product.
as far as quality, they are unclipped at full volume meaning if you turn the volume all the way to 35 you get max voltage out and an undistorted signal to your amps. alot of other decks go to 35 but clip at 30. they have low impedance outputs so you can connect alot of amps, crossovers, eq's, ect without losing a ton of voltage. we did a test on the cheapest RF headunit and simulated hooking up 30 RF amps and the output signal dropped .1 volt. they also do the rated output voltage at 100hz. some makers will rate the output at 10k hz...who listens to that. so you could get 4V at 10k but at 100hz you get like 1.5. couple that with a high output impedance and the voltage will go even lower when hooked to an amp. its a great deck for the price that will do everything it says and do it all well. i would reccomend it.
Old Oct 14, 2003
Ed's Avatar
Ed
You work for rockford, right?
Old Oct 15, 2003
alex053's Avatar
left RF a little over 2 months ago..
Old Oct 15, 2003
dups's Avatar
where you at now? or are you in between jobs right now?
Old Oct 15, 2003
alex053's Avatar
i work for Velocity Communications working on large business phone systems. worked for mtx, then rockford..then tried to make some quick money at a sales job, now trying my hand at field service and getting some certs and looking to get into IT
redcloud
25
Aug 12, 2015 01:23 PM
DeadDreameR
May 14, 2002 03:11 AM
NBPCivic
Mar 19, 2002 06:02 PM
honda4life
Feb 7, 2002 09:47 AM
