How do you remove those.....
Old Oct 7, 2003
Silver5656's Avatar
Silver5656 is an unknown quantity at this point
plastic clips that hold in the side carpet of the trunk?.....man they are a pita....i took off the ones that hold in the carpet on the bottom and ended up breaking one.....i have the tool that looks like a piece of metal with a slot in it to remove it but ended up bending/breaking it....why is it so hard to take out?...am i missing something?....i even pulled one so hard that it broke the cap off but the rod is still inside....sheesh!.....also i was planning on building a subwoofer box to mount flush against the rear seats but that doesnt seem possible....too many bumps/wierd edges near the rear seats....any suggestions?
Old Oct 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
are you talking about the ones that have a tiny circle in the middle? or the ones that have what looks like a flathead screwdriver hole in the middle?
Old Oct 7, 2003
Silver5656's Avatar
um....neither?.....these have "gills" on the side that hold it in.....
Old Oct 7, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Are they the ones with a big protruding head? Like on the sides, the peices you attach your cargo net too?
Old Oct 7, 2003
Silver5656's Avatar
i dont see how u can attach a cargo net to it....the top of it is flush....and it grips into the holes......wow i thot this would be a simple question/answer.....its a 2k1 civic sedan lx.....there are only 2 types of plastic insert bolt thingys......one is a screw type.....the other is this funky wierd one
Old Oct 7, 2003
Silver5656's Avatar
http://www.ericthefat.com/clip.jpg
http://www.ericthefat.com/clip2.jpg
the one on the left is the one im having trouble with....the right one is the screw one....thats easy to take off....also where can i buy the left clip?....i broke 2 of them
Old Oct 7, 2003
Mystic3030's Avatar
A panel popper should take that out no problem, without damaging it. If you are using a panel popper and it's breaking them, then you are doing something wrong...heh. And you can get those from your Honda dealer....they are probably like a dollar each.
Old Oct 7, 2003
Silver5656's Avatar
well when i try to take it out with my panel removal tool it just grips the harder i try to pull.....i've owned a 98 civic and my friend has a 2k civic and they dont have these.....
Old Oct 7, 2003
Silver5656's Avatar
http://www.sounddomain.com/sku/SOU87650
thats what i used
heck i even tried this
http://www.sounddomain.com/sku/SOU87810
Old Oct 8, 2003
Silver5656's Avatar
ok i finally removed it.....sheesh....had to use the the removal tool and pliars to squeeze them out simultaneously
Old Oct 9, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
actually, those are more expensive than you think. i bought 3 of them when i broke mine, and it costed me around 10 bucks. you might be able to find them somewhere such as autozone/advance, pep boys, etc.
Damn HeadGasket
Aug 23, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
