Help! MAJOR ENGINE NOISE & WHIRLING
Old Oct 5, 2003
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
I dunno what happened...when i had one sub in my car there wasnt any noise and nowthat i put in another thheres crazy noises! I know its gotta be something with the wiring in my car...the grounds are good so it cant be that.
On the driver's side of the car runs two sets of rca cables, speaker wires from the left side of my components
On the passenger's side is the power wire, the right side of the component speaker wires, remote sensor wire to the headunit. i've got a lot of slack in some areas so i'm not sure if that could be the prob and the way i routed all the wires(through the side panels on both sides and under the rear seat. I have two amps...one for the subs and one for the components. I grounded both of the amps to the back of the rear seats at the bottom corner. No clue what to do next...tried everything!!! Thanks in advance.
Jeff
Old Oct 5, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i have engine noise to its because of my messed up amp. check your amp or ground.
Old Oct 5, 2003
TopFuel's Avatar
Ultimate OG Member
damn i hope it isnt my amp because both my subs and components respond to my engine noise...brand spankin new lanzar amps. Dunno where else i can ground if its that.
Old Oct 5, 2003
TopFuel's Avatar
Ultimate OG Member
i've been reading around...regrounding the headunit to the some part of the body...would that even make a difference?
Old Oct 5, 2003
sadboy916's Avatar
i hope its not your amp either bro im not good at wireing ect ect i know how it feels when stuff goes wrong with ice it sucks.
Old Oct 6, 2003
dups's Avatar
dups is an unknown quantity at this point
I would bet on either the headunit or the ground for the amps. I know you said you've checked the ground, but what do you have them ground to? They need to be ground to an actual part of the chasis, not just any metal will do. It sounds like everything else is ok. You just need to make sure your RCAs don't cross the power wire at any point at all as well.
This is some good things to test to try to figure out where the noise is coming from...
http://www.crutchfield.com/S-0DHBsTICZKx/tech/kb41.html
Old Oct 6, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
I doubt it's your amp. However, Try getting a 10 amp noise filter from your local radio shack or Best Buy or something like that. Usually they should have noise filters for people like you guys.
If you guys are using the regular CRAPPY RCAs and speaker wires.. they are single plane shielded so they'll let in A LOT of engine noise and electrical noise.
However, if you're willing to drop some extra money, go with some higher end interconnects and speaker cables.
My recommendations are the:
Interconnects (RCAs)
Rockford Fosgate Stealth Twisted
Monster MicroXLN (XLN == xtra low noise)
Speaker wire
Monster XLN speaker cable.
All these cables are twisted and heavily shielded to prevent engine noise from getting into your music.
Old Oct 6, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
As you mentioned above, try running the ground of the HU to the same point as the ground of the amps. I did this and all my whining went away.
Old Oct 6, 2003
dups's Avatar
I've tried the noise filters from radio shack and they seem to be decent, but I think its the lazy way of doing it. It doesn't seem to get rid of all the noise. There is no replacement for just correcting the problem the way it should be. I'd follow the steps suggested in that crutchfield article so you can at least narrow down the source of the noise. Whether its the Headunit, Amp, or something in between. Good luck!
Old Oct 6, 2003
NoSpleeny's Avatar
If you are running 2 amps.. make sure your amps are grounded at the same point! Or you'll have MAJOR feedback noise.
Old Oct 6, 2003
TopFuel's Avatar
Ultimate OG Member
thanks for all the feedback guys! I'mm spend tomorrow afternoon working on this. Let you know what happens.
Jeff
Old Oct 6, 2003
fonto's Avatar
The LA Clipper
Did you move any of the wiring around when you added the sub? Did you take the radio out for any reason?
Old Oct 6, 2003
NoSpleeny's Avatar
damn fonto..
that's some serious audio stuff you got in your car.
Old Oct 6, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
How do you figure? I have 3 amps and a cap all grounded in seperate spots with no noise.......
Old Oct 7, 2003
dups's Avatar
I always thought it was better to have them grounded in the same place as well. I dunno though.
Old Oct 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
Speaker wire
the noise floor in a car is so high that if PROPERLY ROUTED, youll never hear a difference... ive switched between radio shack rca's and stinger rca's and never heard a single difference...
also, speaker wire does not pick up noise, especially when running an aftermarket amp. rca's are oinly dealing with 1-4 volt signals, which are down at the level where noise is a problem, when dealing with a 20 volt ac signal, .1 volts will not really be an issue... ive routed power wires next to speaker wires without a SINGLE problem...
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
silvervtec01
Dec 9, 2001 08:50 PM
