Which color stereo wire is the Turn-on Lead?
Old Jul 18, 2003
mischa49's Avatar
mischa49 is an unknown quantity at this point
Question Which color stereo wire is the Turn-on Lead?
Im doing an Amp install but I dont know which color wire from my stereo is the turn-on lead wire, the wire that will que the amp to turn on when the stereo is also on. Thanks for the help everyone.
Old Jul 18, 2003
VNlilMAN's Avatar
The Standard One
its not blue?
Old Jul 18, 2003
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
Power antenna lead off of radio will work (blue) if it dont have one, tap into the red acc power wire thats what i had to do before
Old Jul 19, 2003
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Yea, completed my amp install, it was the blue one, just had to consult my stereo manual. Thanks for the help guyz.
Old Jul 19, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Actually some headunits have 2 wires coming out that are blue. The solid blue is power antenna and the blue w/ white stripe is the one you want to use for the remote turn on.
If you use the wrong one your amp will shut off when playing a cd.
Old Oct 7, 2003
Silver5656's Avatar
Silver5656 is an unknown quantity at this point
is it the same for a stock headunit?
Old Oct 7, 2003
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Blue for aftermarket, as for stock check the wiring diagram on the site. Not too sure
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Lopes101
Jun 7, 2015 08:04 PM
4 banger
Jun 5, 2015 01:44 AM
CraigW
May 24, 2015 09:49 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
