serious help on speakers
(SnOwBoArDeR | FoReVeR)
i bought a coupe 03 2 weeks ago....and the first thing i wanted to change are the speakers
front speakers are easy u just take out the door panels
but the back speakers is another story, iv been lookin up down right left for 1 week now, and still i have no clue how to take those damn speakers out.
so if u guys found out a way, show me it would be great thx
Please search next time....this has been covered many times before!
1. Remove one (1) 10 mm bolt from space between center of seat bottom and seat back cushions. Pull front edge of seat bottom upward to release hooks and remove (Figure 1).
2. Fold down both rear seat backs. Fold back carpet flap on back of passenger's side seat back. Remove two (2) 10mm bolts from seat bracket. Lift section of seat back and pull to remove (Figure 2).
3. Remove one (1) 10mm bolt securing seat bracket. Lift seat section and pull to remove.
4. Pry out both pillar rimpanels starting at the top. Continue prying downward to release and remove.
5. Remove two (2) 14 mm bolts from seat belt guide on passenger's rear side panel. Remove guide (with belt) and lay aside (Figure 3).
6. Pry open screw cover behind grab handle and remove one (1) phillips screw from opening.
7. Remove one (1) push pin retaining clip from rear side panel located near wheel well.
8. Starting at the rear of passenger's rear side panel, pry out panel and work toward door opening to release and remove.
9. Pull to release three (3) plastic fold-down clips on front edge of rear deck panel (Figure 4).
10. From inside trunk, disconnect brake light wiring harness located under rear deck.
11. Starting on passenger's side, work hands under rear deck panel to release clips. Work across panel. When clips are loose, work panel toward passenger's side. NOTE: Lift driver's rear side panel to work deck panel from under side panel. Remove rear deck panel.
12. Remove four (4) 8mm screws securing speaker. Pull out speaker, disconnect and remove.
13. Connect speaker wiring adapter of replacement speaker to vehicle speaker connector. Secure new speaker with screws previously removed.
14. Test speaker operation and reassemble rear of vehicle by reversing disassembly steps.
Islesfan
Sep 29, 2015 03:42 AM
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
