Alpine HU owners.....help me
Old Oct 1, 2003
madmax's Avatar
madmax is an unknown quantity at this point
Help would greatly be apreciated from anybody with an alpine hu.
The thing that I cant seem to fine tune in my car is the time correction adjustments, and also the hi pass/ low pass filters , just cant seem to get things right!
I have the cda 9811 HU
two 10's in sealed box, running off an 2 ch amp
fronts is type R 176 components, runing off an 2 ch amp
rear 6*9's running off the hu
Also wondering if I should run the sub amp on full range and use the hu controls for low pass/ freq.......or run the amp on low pass( 85 htz) and not touch the low pass on the hu...
what are the settings you guys use?
thanks in advance!
Old Oct 1, 2003
madmax's Avatar
PLEEEEEAAAAAAAASSSSSSSSSEEEEEEE !!!!!!!
thanks
Old Oct 1, 2003
AlpineCivic's Avatar
OK first if you can measure (in inches) from your speakers to where you want the sound stage to be I can give you the time correction settings.
As for the crossovers you want to set your low pass filter at 100Hz (as a starting point) and below and your high pass filter 100Hz and above (also as a starting point). After that it's pretty much user preference, adjust it to the way you like it.
if you need anymor info let me know.
Old Oct 1, 2003
madmax's Avatar
Could you do me a favour and write down the settings that you have stored, we're driving the same car so the settings must be close....?
the 9811 hipass/ low pass only go 80/120/160 and not 100 htz ????
Thanks
Old Oct 1, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Its all user preference.
Personally I prefer the sub crossed over around 65 Hz. My deck has 50/80/125. So I had to use my amps fully adjustable crossover 45-160. This keeps things from getting boomy. Then I keep the highs full range since components already come w/ crossovers.
You gotta play with the sub and highs to see what you like best.
Old Oct 1, 2003
doubledeuce2k2's Avatar
see i set my fronts high pass settings at about 80-100Hz so thay don't bottom out at high volumes. but then mine is adjustable from 40-180Hz too
my subs get 80 and below (i like bass )
Old Oct 2, 2003
mattymatt's Avatar
mattymatt is an unknown quantity at this point
For the time correction you should really do the measuring yourself because not everyone sits in the same position. For instance some people sit very far back and some sit very close to the stearing wheel. It's really not that difficult, just measure the distance from every speaker to where your head is in the car and then go to the I-Personalize section of the alpine website and enter those numbers.
Old Oct 2, 2003
madmax's Avatar
Where should i measure from ????
I have components in the front , so do you measure from the tweeter which is in the a pillar , or from the mid woofer that is in the door ( stock location). ?????
what did you guys do???
Old Oct 2, 2003
mattymatt's Avatar
I just checked the alpine website and it says to measure both. Have you even been to the I-Personalize? If not just read through it, it's pretty easy to use.
Jeffdp
Aug 5, 2015 11:38 AM
Unleaded
16
Jun 21, 2002 09:15 PM
scrible
May 2, 2002 02:32 PM
PiCASSO
Apr 6, 2002 12:18 AM
SiLvEr2001CiViC
Feb 18, 2002 07:05 PM
