Help!! Image Dynamics IDQ12
Old Sep 30, 2003
DIMO's Avatar
DIMO is an unknown quantity at this point
I'm going to purchase 2 12in Image Dynamics IDQ12, should I get the 2ohm or 4ohm version? What amp should I get and how should it be wired up? Each sub should get 350watts rms.
Old Sep 30, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
I would say get the 2 ohm version. Then you can end up w/ a 2 ohm load which is what most monoblock sub amps want.
The two amps I have recently used are Kicker 400.1 and Alpine M350. Both performed great.
Here are some common amps that come to mind.
Kicker 600.1
Alpine M500
JL Audio 500/1
Rockford Fosgate Power 501bd
MTX Thunder801D
JBL 600.1
Old Sep 30, 2003
GreenNVicious's Avatar
Newbie
If you go with the 4ohm, I suggest Phoenix Gold amps.
Old Sep 30, 2003
LudlamTheory's Avatar
i boogie for the raindrops
the ohm load youd want all depends on which amp you get
Old Sep 30, 2003
Regularjoe's Avatar
Two speakers, DVC 4 ohms:
* Mono - 4 or 1 ohm total
* Stereo - 2 or 8 ohms each speaker
Two speakers, DVC 2 ohms:
* Mono - 2 ohms
* Stereo - 1 or 4 ohms each speaker
Since they are subs you most likely want a monoblock class d amp. If so w/ the 2 ohm ones you want an amp putting max power out at 2 ohms. With the 4 ohm ones you want an amp that puts out max power into 1 ohm.
Old Sep 30, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
GOOD CHOICE IN SUBS! I have the idq12 v2 d2 dual voice coils.. I have each sub wired in series to make a 4 ohm load, then paralell so my amp sees 2 ohms mono.... I've had these subs for over 3 years and they are awesome....
h4ldol
Apr 24, 2017 08:16 PM
shadowfist
Oct 18, 2015 02:38 PM
General DIY
Sep 25, 2015 08:02 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
