high volt. output HU
Old Sep 22, 2003
BRCivic's Avatar
BRCivic is an unknown quantity at this point
I want to get a high voltage output HU so i don't have to turn my amp gain up so damn high. This is the cheapest I have found that looks like a good deal:
Panasonic CQ-DF903U
It's got a 5v preamp output, so that should be a nice improvement over the current 2v output on my Pioneer. Reviews of it look good so far.
Anybody ever used this cd player or have any comments?
Old Sep 22, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
The Panasonic HU my ex g/f had was crap....stopped working after 2 months, got replaced 3 times under warranty before she finally sold it and got an Alpine.
I forget the model, but it was like $220 at Tweeter about 2 years ago.....
Old Sep 22, 2003
Mystic3030's Avatar
Here, the alpine has 4v preouts...there wont be a noticeable difference on gain settings between 5 and 4, and it's almost $100 less than the Panasonic.
http://www.ikesound.com/product-product_id/1300
This Pioneer is like $20 more than the Panasonic and has 6v preouts and an OEL display:
http://www.ikesound.com/product-product_id/1496
Old Sep 22, 2003
BRCivic's Avatar
hmm... and the Pioneer reads mp3 cd's
Old Sep 22, 2003
LudlamTheory's Avatar
i boogie for the raindrops
or, you could always use your existing hu and buy a line driver
Old Sep 22, 2003
BRCivic's Avatar
true, but now i'm liking the sound of an mp3 player also : )
Old Sep 22, 2003
Logan3024's Avatar
Remember when companys rate power (just like amps) some will give PEAK voltage and some will give RMS voltage( to help fool consumers). 5 volts is the peak for the panasonic, But Alpine rates their rca voltage in RMS.
Old Sep 22, 2003
but ive both tested and read tests from alpine decks... not ALL of them put it out their rated voltage... even the lower end nakamichi's are rated in peak...
my clarion puts out its rated power, i know that
i still vote for the line driver
Old Sep 22, 2003
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
hey ludlam, how did you test the output?
i was at my local shop, and their diamond audio rep showed up, he was looking at the panasonic units the shop had and decided to test the 5v output. he had some sort of handheld device that showed output from rca as a sine graph i believe. when you get distortion out of the HU, the sine graph started to skew and look irregular, he said thats how you know its clipping. so he basically looked at the graph until it distorted, then he got out a volt meter, and measured the voltage output before clipping. does that sound right? he looked like he knew what he was doing, but the shop owner told me after the diamond rep left that he was known to BS a lot, so i didn't know for sure.
btw, they tested the output of panasonic 903, 3.3volts before clipping, they got 1.7volts out of the clarion 835mp (but it was defective, so i dunno the real output).
Old Sep 22, 2003
alex053's Avatar
eclipse has a 16 volt balanced output. i think 8 volt is the highest unblanced output.
Old Sep 22, 2003
slick, the box he used with the sine graph is an oscilloscope.
Old Sep 23, 2003
BRCivic's Avatar
ok, but since i have a Pioneer HU now that has a 2v output, and the one i'm looking at is a Pioneer w/ 6v output, wouldn't the 6v one still be approximately 3x the output of what i have now, even if it is not technically 6v?
b/c in that case, it should still be a major improvement
Old Sep 23, 2003
that pioneer only has 4 volt outputs... i dunno where you saw 6... the 1200 dollar pioneer unit doesnt even have 6 volt outputs, i think it only has 5 volts
Old Sep 23, 2003
BRCivic's Avatar
http://www.pioneerelectronics.com/pe...006488,00.html
...straight f/ the pioneer website, but it could mean peak or something
but anyway, i'm looking more at these line drivers, b/c i've been reading some good things... (not to mention I know you know your **** and you said to get one). If I go this route, should I go w/ an expensive one w/ separate subwoofer outputs and whatnot? Or would I still get great performance f/ a cheaper one like this
Old Sep 23, 2003
BRCivic's Avatar
...or even this
Old Sep 23, 2003
alex053's Avatar
heres what it boils down to. the gain structure of the amp your using and the amount of clean signal you can put into it. when i worked at rockford, the amps were set up from .5v to 8V max. so if you had a .5v input signal and the gain all the way up, you would get advertised power. now if you have an 8 volt input and the gain all the way down you get the max power out of the amp. the 8 volt will sound better because of signal to noise ratio. the higher the voltage signal the the lower the noise floor.
slick: we did that same test with the 199 RF deck against an alpine @ 100 hz the advertised 2v output did .6. the rf did 2.3. with a load on the output the output of the deck dropped to .43 volts and the rf dropped to 2.2. now with my explanation above this is a big deal because even with the gain pegged, you wouldnt get the advertised power out of most amps with that alpine deck. now keep in mind this is at the $199 price point and im not bashing alpine..just stating what our test showed. the thing that caused the voltage to drop when connected to a piece of equipment is the output impedance of the deck. you want this number low so the voltage doesnt drop as you connect more items (more than one amp, processor, eq, ect...)
Old Sep 23, 2003
slick's Avatar
that little dude
thats interesting Alex053, i wonder how well the higher output alpine units do? or for that matter, higher end units like nak cd-400, or eclipse units.
thanks ludlam, i guess calling it the box thing that makes sine graphs isn't the name for it, lol.
i was wondering, lets say the RMS voltage of a 4v unit is 2.5v. so you set the gain on your amp, and the gain was set to match the 2.5v coming in. but the max voltage is 4v, so when you're playing music, the voltage spikes upto 4v, how does that affect the amps output? i mean, you set the voltage for 2.5v, but it jumps to 4v, wouldn't that confuse the amp? i dont get it, shouldn't the voltage be as consistant as possible>
Old Sep 23, 2003
slick - noone really sets their gain with a scope anymore due to the dynamics of music and everything else... I set my gain with a dilated peoples song, other use sine waves, others use other things...
Old Sep 23, 2003
Connie's Avatar
My old Sony HU that I am selling has a 5.5Volt output. I am pretty sure that Sony and Eclipse make the highest volt outputs, I sure do miss the sub sound from my last HU...
Old Sep 23, 2003
are we talking one of the old school sony ES units?
those are great great HU's.. why cant sony no longer make a respectable deck
Old Sep 23, 2003
alex053's Avatar
ya..older es decks were super nice.
c-90 anyone??
Old Sep 23, 2003
My pioneer has 6V preouts (940MP model). Higher voltage really matters with amps for a cleaner signal.
Old Sep 23, 2003
BRCivic's Avatar
i ordered the Phoenix Gold line driver f/ SoundDomain.com for $90 shipped. It should be here by the end of the week... I'll let you know the result when I put it in.
Old Oct 1, 2003
BRCivic's Avatar
ok, well i have it in, and i've been playing with the settings on both it and my amp for only a little while now
thus far, i do find that the bass is a little louder, but the main advantage is that w/ the power i have now, i can have all my HU settings set to flat, and my music SQ is much better overall.
Plus, i can blare bass for almost an hour and the amp is barely even warm b/c the gain is only about half way up : )
MamaBear2015
49
Sep 29, 2015 01:12 PM
7thgensurvivor
Aug 28, 2015 08:39 PM
JetsterDajet
Aug 16, 2015 01:56 PM
silentz
Jul 9, 2015 08:16 PM
