Ground for AMP
ah your crazy, u dont need to drill any new holes, lift the carpet from your truck, and there are many decent sized blots that pass through the body, some even the frame. find a good one, clean it up, scrape the paint off for the best connection and a little grease if u wanna keep it clean. just make it as close as possible
Electric Boogaloo...
decide where you're gonna mount your amp. from there, find an inconspicuous spot, get something to clean the paint off the trunk floor (the metal one, not the false floor). run a screw into the spot where the paint is stripped off, and into the terminal for the ground wire. and you're done.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
260000milesgoal
Sep 25, 2015 07:41 PM
