Speaker Baffles?
Old Sep 20, 2003
MaThMaTiKz's Avatar
MaThMaTiKz is an unknown quantity at this point
Speaker Baffles?
Has anyone used speaker baffles before? .... Are they worth getting? .... also, i figured, since the foam baffles are between the metal panel and the speaker, does this stop some of the annoying vibration sound that is associated with the rear deck? .... idunno, just seems that 8 bucks for some baffles wouldnt hurt so much ... or am i wrong? LOL
Old Sep 20, 2003
doubledeuce2k2's Avatar
they give your speakers a little more bass (kinda like sealing a sub, only a lot smaller and not a tight seal). they won't do anythign for the rattle, maybe make it worse if anything. but coat the back deck underneath with something soft (cloth, rubber [i used that stuff you put on shelves in the kitchen to prevent plates from sliding, and it came in so many neat colors ]) and make sure it goes to the glass, and that should nix the rattle.
Old Sep 20, 2003
MaThMaTiKz's Avatar
hmmm that sounds like an idea ..... do you know what those baffles are made out of?
Old Sep 21, 2003
WhiteRabbit's Avatar
foam. definitely convenient, as you can poke a small hole for wires, and you cna get a size too big and you dont have to worry abotu the window, its nice and soft and flexible. totally helps midbass significantly in our cars, ask hobbes abotu that one, i put in his earthquake 5's with those foam baffles, worked great.
i highly reccommend them for door speakers
Old Sep 21, 2003
MaThMaTiKz's Avatar
excellent .... i think this will be my next weekend project ...... now, as for the rear speakers ....... will the fact that the foam is now separating the speaker and the rear metal panel, will this help dampen the vibration a bit? and will it improve sound quality as well?
Old Sep 21, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I have 6.5" foam baffles in my doors and they do work awesome. Definatly helps out the midbass. Also it will help your rear speakers if you have subs because the pressure coming from your subs wont be directly on the backside of the rear speaker cones. So not only will you have better midbass but you'll have almost no distortion on your rear speakers caused by your subs.
Old Sep 22, 2003
scarpones's Avatar
scarpones is an unknown quantity at this point
does anyone have any pics of their baffle installs?
Old Sep 22, 2003
theres nothing ot take a picture of, you just put the foam in and sandwhich it between teh speaker and the mounting plate
Old Sep 22, 2003
scarpones's Avatar
ahhh ic ic
i figured is a foam box for the speaker, similar to a box for subs
n/m
Old Sep 23, 2003
it is. and you sandwich it between the speaker and the mounting plate
Old Sep 23, 2003
scarpones's Avatar
ahh cool cool
me slow today
Old Mar 18, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
can you stuff cotton in the baffles?
would that help and thing?
what was it again to help the virbrating/rattling?
thanks,
david
Old Mar 18, 2004
its to improve midbass response. the idea is to restrict the back wave a bit more, kinda like the difference from playing a subwoofer jsut sitting on your floor versus putting it in a box.
this isnt a box, and far from perfect, but it does restrict the air wave a bit, so it helps.
i dunno abotu stuffing it, ive never heard of anyone doing it, try and see! who knows, maybe itll help
Old Mar 18, 2004
i stuffed my door with polyfill. seemed to hep some. cut down on air, thus making a smaller free air setup.
Old Mar 18, 2004
draganjr's Avatar
i am going to do the rear and the front with baffles and stuffing them both with cotton or polyfill.
the speakers i am getting are 2 1/4"!
and the baffles will be 2 3/8"!
would that be good?
thanks,
david
Old Mar 19, 2004
thatll be fine, foam flexes!
Old Mar 22, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I have baffles for my XR mids. I didn't necessarily get them for better midbass, rather to keep water off of my mids. My doors leak alot from the seals around the window when it rains and I don't want water to screw up my expensive mids.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
