more vibrating from the back
Old Sep 18, 2003
scarpones's Avatar
scarpones is an unknown quantity at this point
i think the rear seatbelt assembly's or them actually vibrating against something is causing some bad noise when i crack up the subs. i only have 2 JBL 10" with a 300.1 amp, and 1/3 of the way up, i can already hear alot of vibration.
any suggestion to prevent this?
Old Sep 18, 2003
I have everything back there dynamatted and foamed--I still hear the rattle. I think it's internal to the middle seat belt assembly. Nothing you can do.
Old Sep 19, 2003
LudlamTheory's Avatar
i boogie for the raindrops
expanding foam and/or fiberglass will help... its also the rear deck hitting the window... i carpeted my rear deck and it all went away
Old Sep 19, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Yup...my rear deck is carpeted, and there is abosultely no rattle back there....the other thing i've done on some of the NE members cars is use 3/4 foam weather stripping on all the edges of the rear deck that come into contact with the window. That does work, but not as well as the carpet.
Old Sep 21, 2003
scarpones's Avatar
yeh i used a thin gasket along the window and back deck, i actually took out the back seats, all the panels, including the back deck. all was left was bare metal, and you could still hear alot of vibrations.
i guess nothin to fix it
Old Sep 21, 2003
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
What kind of carpet do you use, where do you get it, how does it match, and how did you do it. I have some 3M spray glue that would probably work. I know I saw a thread about it a long time ago, and saw a pic of WhiteRabbit's deck, and never PM'ed him about it.
Old Sep 21, 2003
Mystic3030's Avatar
Go to a car audio shop, or a car upholstry shop....tell them what you want to do, show them a sample of your carpet, then they should be able to find you a match
Old Sep 22, 2003
scarpones's Avatar
so u carpetted the bottom of the deck, or the top part of the trunk? and what kind of foam did u spray and where?
conspiracy90
Jun 7, 2023 01:01 PM
Ocenica
May 30, 2015 06:53 PM
mrohitredd
18
May 14, 2015 07:35 PM
jakeconnor
May 5, 2015 07:30 AM
streetglower123
Apr 12, 2015 10:56 AM
