First time HU installer question.
Old Sep 15, 2003
bmark3's Avatar
bmark3 is an unknown quantity at this point
I have a 2003 Honda Civic LX coupe that I bought a Pioneer DEH-P5500MP HU for and am about to install. I think the install will go ok except I'm not sure about one of the wires coming from the harness. From the Pioneer harness there is a Blue/White wire witha female metal connector that says the following in the manual " to system control terminal of the power amp or auto-antenna relay control terminal". On the wiring harness that came to connect the new HU to the stock harness there is a blue/white wire that says "power antenna" on it. Do I connect these two together? Also since there is no male connector on the non-Pioneer harness should I trim the female end and connect that way or buy a male connector and connect it that way? Thanks for the help, I'm a newbie so please be gentle if this is a repeat I searched first and couldn't find exactly what I was trying to ask.
Old Sep 15, 2003
Litespeed's Avatar
Litespeed is an unknown quantity at this point
That sounds like the remote turn-on lead wire. That should be the wire that connects to an external amplifier that turns on the amp when the HU is on. So i'm pretty sure that you could just leave that one alone unless you have an external amp. Not everyone makes wiring harnesses with the same color codes. Also... you don't have a power antenna. Just make sure everything works as it is suppose to before you screw everything back in.
Old Sep 16, 2003
UrbanHaze's Avatar
UrbanHaze is an unknown quantity at this point
Well, since we're talking wiring... =)
I recently took out my old DEHP 6400 and *ahem* tried to install a DEHP8500MP, and it works fine, but since then my lights in my dash, the ac control lights, and my shifter lights dont work...
I've already posted about this in the problems/issues section, but I figure I'd get more coverage this way.. I've already checked and rechecked fuses
On the pioneer there is an orange wire with a white stripe that says illumination, and on the Honda wiring harness, 2 orange wires.. one without a white stripe that says illumination, and one WITH a white stripe that says Dimmer... I just connected the 2 illumination wires... Did i mess up? i cant my lights on the dash to work anymore!!
HELP!
Thanks
DOug
Old Sep 16, 2003
bmark3's Avatar
Since my DEH-P5500MP doesn't have a dimmer I just left that wire capped off. I've had no trouble as of yet with any interior/exterior lights not working. Hope that helps. There's also one fuse that everyone seems to miss from what I've read on other posts, I think its labeled "backup" but don't quote me on that.
Old Sep 16, 2003
doubledeuce2k2's Avatar
yeah although they say illumination/dimmer, i think you want to connect the dimmer wire (from honda) to the illumination wire (from pioneer). the purpose of that wire is to be hot when the headlights are on so the buttons light up.
Old Sep 16, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Yes we do have powered antennas. That doesnt refer to a power retractable antenna, it's for the booster. If you dont hook that up, you can forget about getting FM reception.
pratik05
May 15, 2015 01:54 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
carid
Apr 30, 2015 07:00 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
