please help! amps keep dying
Old Sep 14, 2003
BRCivic's Avatar
BRCivic is an unknown quantity at this point
OK, my 1-month old Fosgate 801x just died last night in the middle of music playing. The bass just stopped playing all of the sudden, but the amp was not hot at all b/c it had only been playing for like 2 minutes. However, the amp did run really hot normally when it was playing on a normal basis. The fuse in line in the power cable is not blown, so that's not it.
I have 4 gauge power cable and ground cable, but I'm wondering if maybe my ground isn't good enough or something b/c i didn't grind it down where i grounded it. Would that make it run hotter? I've had 2 amps before this one die in the last couple of years, and I want to know if it is something in the wiring causing it.
Any help would be greatly appreciated, thanks!
Old Sep 15, 2003
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Did you check the fuses on the amp itself? Also, some amps tend to run hot which is usually not a problem. If you're worried about it running too hot, then consider the location you mount your amp. If it's somewhere with bad circulation or a place that tends to get warm in your car, then it is possible it will overheat. These are the only suggestions I can think of. Otherwise you might want to take it in for inspection/repair.
Old Sep 17, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
the fact that you've had 2 other amps "die" on you scares me. You should never have an amp do that, much less 3 of them! Where does your ground wire connect to the chassie?
~Tbone
Old Sep 17, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
How are your subs wired? If you are below 2 ohm that could be the problem...I seem to recall that rockford amps dont like to go below 2ohms...alex would be the guy to talk to though.
Old Sep 17, 2003
tbone323's Avatar
its tru that RF amps dont handle low impedance loads well but that will only cause the amp to go into protect, not kill it. I have a BD1500 in my car that isn't a fan of 1 Ohm but when I set it up that way to see what it would do, it just shuts down when you crank the volume (and dump loads of current into the speaker)
Old Sep 18, 2003
BRCivic's Avatar
Amps have all been running at 4 ohm. However, I am using my gain about 80% up.
They have all been grounded to the pre-drilled holes in that little pertruding (sp?) metal bar that separates the trunk f/ the back seat area.
Next time i go home, i'm gonna grind the area down some first, but what should i use to do it?
Old Sep 18, 2003
Mystic3030's Avatar
A dremel....or sandpaper if you feel like scrubbing for a while.
Old Sep 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
sounds like you have your gain set to high.... I've never had my gain on any amp set more than half, usually around 1/3.. but thats because I always use head units with high voltage outputs..... remember the gain is not a volume control, but a level. Make sure you are setting it properly!
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Le Ormz
Sep 30, 2015 09:24 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
