mmats amp alpine head unit and power problems
Old Sep 6, 2003
knappster_21's Avatar
knappster_21 is an unknown quantity at this point
Question mmats amp alpine head unit and power problems
i just recently had my system installed and here is what it is composed of.... i have an Alpine 9815 head unit, a MMATS dhc1400.1 amplifier, 2 Kicker L7's in a ported box, and a stinger 1 farad? cap, and the wire to the amp is 1/0 gauge. Well the problem is when i turn the music up the amp draws so much power my lights dim really bad and my head unit completely shuts off. i had the capacitor installed thinking it would solve my problems but it only help just a little bit. the people at the audio shop said i need to get an optima heavy duty battery put in my trunk. ny question is will this solve my problem? because i dont mind spendin 150 on the battery if it is gonna fix my problem. if it wont fix it do any of you have any suggestions that might work. all help is greatly appreciated. thanks
Old Sep 6, 2003
LudlamTheory's Avatar
i boogie for the raindrops
well, have you upgraded the big 3 under the hood?
also, are you running the stock battery?
Old Sep 6, 2003
um what is the big 3? and yes i still have stock battery under the hood. thanks
Old Sep 7, 2003
big 3 is your stock grounds, your battery to alternator, adn battery to fusebox...
hondas are infamous for using horrible stock power cables...
and id probably reccomend upgrading the stock battery instead of adding one
Old Sep 8, 2003
do i need to replace all of my grounds like battery to chassis or just a couple. either way could you tell me which ones to replace and where i can get all the replacements at and what to replace them with. i really apreciate your help alot.
Old Sep 8, 2003
you replace them with regular old 4 gauge power wire and the more you replace the better
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
BabyLX
Nov 16, 2001 05:53 PM
