2k2 Civic LX: Weak AM signals, need help!!!
Subscribe
Aug 23, 2003
i just swapped out my stock headunit for a panasonic headunit, but now the AM signals are weak. i know many don't use AM, but i need it for AM traffic stations and my parent's chinese stations. i tried grounding the antenna amp directly to the battery, but it didn't help. does anybody know how to increase the antenna's amplifification? what other honda models' can i use? i know people swap nsx antennas with integra ones for the stub look, but what will work for our 7th gen civics?? thanks
courtesy of hondaautomotiveparts.com
Reply 0
Aug 23, 2003
Your problem sound extremely familiar. Try searching the forums before posting topics like that. Not to say I'm not guilty of it tho.
http://www.7thgencivic.com/forums/sh...hreadid=108652
It's your power antenna. You're not powering it. Run a wire from the yellow/green (power anntena from factory harness) into your amp remote wire or something. You'll see great improvement in AM reception.
Reply 0
Aug 23, 2003
nohone.. i tried that, and it still sounds like ****..
Reply 0
Aug 24, 2003
what if i tapped it straight to the battery? will it short it module?
Reply 0
Aug 29, 2003
I used to have an FM signal booster in one of my previous vehicles, and it worked great. Would something like this help?
AM/FM signal booster (Crutchfield)
Reply 0
Aug 31, 2003
hrm... that's something to look into. thanks.
Reply 0
Subscribe
