2002 4dr LX front speakers
Old Aug 19, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
I'm curious...
If I drop in a pair of front speakers with mounting depth of 2.5"... they wont' fit right?
If they don't... and I use a spacer... will the door panel go on properly after or will I have to modify?
Old Aug 19, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
I have the exact same car. And you're right, just dropping them in won't work. I made a couple of mounting rings out of MDF, both are 1inch deep, and the speakers went in with enough clearance for the window, and the panels went back on perfectly. The only thing is, you'll have to do some drilling to mount the new speakers and rings. Oh yeah, and to line up the rings correctly, before you take out the old speakers, go around them with a felt marker. This will give you a centering area, so you can make sure you put the rings on in the right place so the panels will fit over them again.
Old Aug 22, 2003
dma001's Avatar
dma001 is an unknown quantity at this point
I did the same thing with my speaker install. Make marks or draw around the existing speakers, and the new ones will fit fine. I ordered 1" spacers from Sounddomain.com, and they worked great!
izdman
May 19, 2015 03:43 PM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
