antenna problem I think
Old Aug 15, 2003
mattymatt's Avatar
mattymatt is an unknown quantity at this point
Every time the base hits while I'm playing the radio the reception gets messed up. It only happens when I'm playing the radio, when I play cd's it's fine. I know the antenna is somewhere by the back speakers. So is the vibration somehow disrupting a connection in the antenna? Has anyone else had this problem and how did you fix it?
Old Aug 15, 2003
justplainbad's Avatar
Victory is Mine!
justplainbad is on a distinguished road
Antenna is glass mounted I believe, the actual connection should be located just behind the last pannel on the passanger side of the rear. Its the pannel behind the rear seats, I think...
Also, this may be a longshot, but maybe the bass is drawing too much from your battery and your powered antenna wire isn't getting the full 12 volts? Just something to think about, but its most likely the glass connection.
Old Aug 16, 2003
mattymatt's Avatar
I think if it was drawing too much power then I would be having the same problem when I'm playing cd's. The amps I have are not all that powerful anyway. If it is the antenna that's the problem would the people that installed everything be responsible? Like maybe they loosened the connection or something?
Old Aug 16, 2003
Victory is Mine!
Well, the thing is, if you were playting CDs, you wouldnt hear the radio cutting in and out... Does your HU have both Remote Turnon and Power Antenna Leads, or are they all one wire? Yeah, its possible the vibration is affecting the Antenna, I don't know of anything that could help though...
Old Aug 16, 2003
mattymatt's Avatar
I'm not sure, I had someone hook it up for me.
Old Aug 16, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
There is a booster behind the kick panel on the passenger side, and another plug behind the C pillar in back, you could have a loose wire in either of those locations. Go back to the shop that installed it, tell them you've had that problem since you get the system installed. They shoulde check it out and correct it free of chrage.
Old Aug 16, 2003
mattymatt's Avatar
I brought it to the shop and he replugged everything and reset the HU and now everything seems to work fine. Hopefully whatever they did fixed it for good. Thanks for the help.
Old Aug 30, 2003
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
bringin this thread back....
just got my new 03 civic ex yesterday...fm reception is terrible...no matter where i am...driving thru the city...highway...i get static everywhere.....i dont believe what was posted before about how after you put an aftermarket hu in the signal turns to crap...and even if that does happen....i got lots of cds..the stock stereo is just too poor for me..
http://www.crutchfield.com/S-xEm5Gyw...ech/kb299.html
for the guys who got weak fm and no am..
more fm recept
http://www.crutchfield.com/S-xEm5Gyw...ech/kb300.html
Old Aug 30, 2003
mattymatt's Avatar
I don't think that the problem had anything to do with the HU, it was more of a problem with the antenna connection.
mohawkboom
67
Aug 25, 2015 12:28 AM
cdt12271
Apr 23, 2015 11:36 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
