stereo help plz!
Old Aug 13, 2003
pvillcivi's Avatar
pvillcivi is an unknown quantity at this point
stereo help plz!
While reinsalling my stereo I think the constatnt on positive wire from the battery shorted out on my dash. Now I have no radio or keyless entry has this happened to anyone else out there? I chacked all fuses and that's not the problem. Honda said that if it did short out my car wuold just be a big paper weight. That's not the case. Also my trip meter gets re-set to the odometer every time I shut the car off. Any suggestions would be appreciated.
Old Aug 13, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
--> moved to ICE
Old Aug 14, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
theres a fuse under the hood called backup, try that one.
Ludlam posted this last night i believe, chack that fuse and see if its blown
Old Aug 14, 2003
mudflap's Avatar
mudflap is an unknown quantity at this point
definitely check the fuse labelled 'backup' in the engine bay. if that's not it, check your accessory fuses and stereo fuse under the dash. i suspect you'll find your problem under the hood as i did. i bet you also do not get the lights coming on when you open the door with the key out of the ignition either...
Old Aug 14, 2003
pvillcivi's Avatar
thanx evrybody for the help. It was the "backup" fuse so thanx again all for the help
SammySC
121
Apr 7, 2017 07:43 PM
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
