ZSKCivic01 and components issues
Old Aug 7, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
There have been many posts about ZSKCivic01 blowing his JL components. Well a few days ago we talked on IM, then again last night. I got looking afterward and we have all been wrong about some things.
1) The amp is 75 rms, 150 max @ 4 ohms and the speakers are 70 rms, 150max. So the amp should be fine. It is about a perfect a match as you can get.
2) We were wrong about the HU voltage. It is: Pre Output Voltage (Before Clipping) : 4V Subwoofer (2V Front and Rear) So actually it isn't a 4v output to the amp. Its only a 2v output to the high, only the sub gets 4v. In this case ZSKCivic01 you can probably go to the 3v or 4v setting without worry.
3) Something that came out in our talks is that he was running the bass @ 5-7. Now the bass specs are: Bass Level Control Range : ±14dB at 60Hz (2dB steps) Since its a 2db step adjustment this makes me think that +5 is actually a 10db boost and +7 is a 14db boost. I am positive this is what lead to the speakers blowing. Generally things for the components need to be flat. I would think +1 is a lot and +2 as way too high. There is a independant sub level control that should be used for getting more bass via uping the sub output independantly: Subwoofer Level Adjustment Range : -15dB to 0dB (1dB steps) I would say maybe put the level in the middle. Then set the sub gain. Then you can go up or down 7db from there by controlling it from the deck.
Also something that might help is setting the internal high pass crossover to 80hz. It has: High Pass Crossover Frequency (Selectable) : Off, 80Hz, 120Hz, 160Hz That will help keep bass off the components too.
Good luck.
Old Aug 7, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
We told him to check those things a while ago and he said they were all on zero....
Old Aug 7, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
thats not true, I never said they were all on zero. I have had the bass on my HU up pretty much the whole time at around 5-7.
Old Aug 7, 2003
Mystic3030's Avatar
So this: "Something that came out in our talks is that he was running the bass @ 5-7. Now the bass specs are: Bass Level Control Range : ±14dB at 60Hz (2dB steps)" is a setting on the HU and not the amp?
Old Aug 7, 2003
ZSKCivic01's Avatar
Extreme Member
yea, the bass settings on my HU. My amplifier basically hasn't been the problem throughout this whole mess, its most likely been my HU giving too much bass to my speakers.
Old Aug 7, 2003
Regularjoe's Avatar
Basically your undoing what your crossovers are trying to do.
They should be filtering out bass, probably on a 6db or 12db slope.
You were adding 10db or 14db of bass back in.
Old Aug 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
zsk's amp is 150 rms per chan @ 4 ohms, not 150 max...
Old Aug 8, 2003
Regularjoe's Avatar
I keep finding conflicting information.
Some say rms some don't .... whats the manual say?
Old Aug 8, 2003
ZSKCivic01's Avatar
Extreme Member
The manual says:
OUTPUT POWER RATING(14.4V Battery)
4 Ohm Load - 150x2
2 Ohm Load - 230x2
1 Ohm Load - -------
Mono bridged into 4 Ohm - 500x1
Here is the link to my type of amplifier:
Click Here
Old Aug 8, 2003
Regularjoe's Avatar
Doesn't every specifically state rms or max.
If its max you want about 3v, if its rms you want about 5v on the amp gain setting I would imagine.
Old Aug 8, 2003
ZSKCivic01's Avatar
Extreme Member
For some reason it doesn't specifically state whether it is RMS power or max. Im assuming its max, because it is at 5v right now and those components aren't playing extrememly loud.
Old Aug 8, 2003
ZSKCivic01's Avatar
Extreme Member
I just e-mailed hifonics and they told me that the 150W is RMS power. So I guess ill keep the amp pretty low, I think it is already set at around 5v.
Old Aug 8, 2003
zsk, also youve gotta realize jl xr components arent meant for ***** out loud playing. theyre smooth mellow components
Old Aug 8, 2003
ZSKCivic01's Avatar
Extreme Member
I know that, personally, im tired of listening to them extremely loud anyways. I think the gain at 5V is loud enough now, and at 5V, it isn't ear bleeding loud.
Wezze
Mar 3, 2002 10:53 PM
NitehawkVTEC
Jan 23, 2002 01:42 PM
DogstyleEX
Jan 20, 2002 10:32 PM
AFlyer
Dec 27, 2001 06:16 PM
ademarco6
Nov 12, 2001 06:52 PM
