Finally relocated my amp to the trunk..
Old Aug 6, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Still the same buzzing... then it goes away when I use only one rca... but even with that i get a slight slight whine as the engine revs. loud popping when i hook up two rcas.
I did a 100% clean and professional style install.. all wires routed seperately, quality NEW cables used, gold plated terminals... the works.
Do you guys...
1) Think my amp is defective in any way?
2) Think those noise filters would work... if so.. what are they exactly and how do i use them? Do they at all sacrifice sound quality?
3) Since the amp isnt happy with two RCAs, one seems to work fine, but am i short changing anything like sound quality? Or should i use two y cables for both RCAs?
Old Aug 7, 2003
MangoEX's Avatar
Just Be
ttt
Old Aug 7, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
I had the same problem with mine....I'd try the noise filters, what do you have to lose? Really, can it hurt sound quality any more? And if they don't work, you're out like 15-20 bux. Then you can just ebay the stuff. What kind of amp is it, anyway?
Old Aug 7, 2003
LazyDog01's Avatar
Raceway Park Track Tech.
it not the amp it the head unit...go back over how you have you head unit setup the wires that is. i have the same problemand you dont have to get noise filters. i think it has some thing to do with the lead turn on wire....take a look at that again see what happens
Old Aug 7, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
It's got nothing to do with his turnon wire. Mango: You will loose NO sound quality by using one RCA, the only thing you loose is the ability to fade front to back.
Old Aug 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
mango, have you regrounded your headunit, or are you using the stock ground?
Old Aug 8, 2003
MangoEX's Avatar
Just Be
I've regrounded it to the chassis... instead of through the aftermarket harness... still same results... again my equipment is...
Alpine CDA 9807 HU
MTX 6304 4-channel Amp
Rockford 8 Gauge wiring/Rockford 4 gauge ground w/ gold terminals
Polk/Momo MM465 components in front/cerwin vega 3 ways in back
RCAs: Rockford Fosgate and Schoche.
PS -- Mystic... how does audio signal get to all four signal with the use of only one rca? I believe you, cause it works. Just don't understand how. But as I said, even with one RCA, there's still an ever so slight hum as I rev/drive.. and a LOUD pop when I turn on my HU. Can this pop do any damage to my speakers? It makes me feel like its going to blow the speakers!
Old Aug 8, 2003
Mystic3030's Avatar
The amp just uses the one input for both outputs...kind of like bridging. The pop you are getting sounds like when your amp turns on it sends feedback through all your speakers.....i'm not sure how you would go about fixing that, perhaps it's a defect in the amp. Have you checked to see if any of the speakers are shorting out inside the door? (bare speaker wire touching metal somewhere)
As far as the alternator whine while you drive, does it really bother you? Is it only audible with the music down low? Cause I get a *little* bit of it too with the music low, but I just ignore it......
edit: I think there may be something wrong with your amp....since 2 RCA's causes problems, while 1 works fine not matter what you do.....and the popping when it turns on, even with you completely re-wiring everything. So if you dont have any speaker wire touching metal somewhere, you might want to look into a new amp or something.....
Old Aug 8, 2003
Mystic3030's Avatar
I just had another thought....does that amp have a signal-sensing option? If it does, and it's set to turn on with signal sensing, and you are still feeding it a remote lead that *might* cause the popping....worth checking out.
Old Aug 8, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
try running an 18 gauge wire from where the head unit is grounded to where the amp is grounded. Sounds like you have a ground loop. That might do the trick.
Old Aug 8, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Go to radio shack and get a car audio ground isolator. That should fix the problem.
Old Aug 8, 2003
MangoEX's Avatar
Just Be
You mean for the popping? and guys its a brand new amp.. problem is i bought it from ebay.. dont feel like hassling... i'll try all those things. its just so bothersome to keep popping off all those panels and running wire everywhere. every panel in the car must have came off/put back on at least 10 times (except the dash) HAHAHA.. And Mystic, yeah the whine is only when the music is low not audible when playing regularly..
and what exactly is a ground loop?
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Mc7602
Sep 17, 2015 02:01 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
